Old 10-07-2011, 04:07 PM
bulldog19 bulldog19 is offline
Default Tremec TKO600 Will Not Shift
Just went to head out for a cruise and started the car and went to put into reverse and could not get car into gear. The trans would grind if i tried to force it. I shut the car off and was able to change gears but 1st, 3rd and 5th felt extremely notchy. What is a good place to start looking for potential problems?
Just what I wanted after a 60-hour week!
John
68 Camaro RS Convertible Dual Quad 406 TKO600 Hotchkis TVSS SOLD
Old 10-08-2011, 06:02 AM
67ragtp 67ragtp is offline
John,
It sounds like the clutch is not disengaging. I had a similar situation about a month ago. My car sat in a dampish garage for 3 months when I got in pushed down the clutch put it in neutral started the car. Pushed clutch in and wont go in any gear. I new immediatly the clutch disk married itself to the flywheel even though the pressure plate pulled away. Some friction materials built into the disk can develope a bit of corrosion over time in the right conditions and stick to the flywheel. All I did was shut the car off in first gear and rock the whole car back and forth and it popped free.
Did yours run well prior to putting it away last?
Is it a hyd bearing or manual linkage?
Rich
Old 10-09-2011, 03:19 PM
Rich, car ran fine no issues. The linkage is mechanical. I can only get into gear with engine off. Car will not start in any gear only neutral. Do I need to discconect neutral safety switch in oder to start in gear then shutoff and rock?
thanks for the tip.
John
Old 10-09-2011, 05:24 PM
ccracin's Avatar
ccracin ccracin is offline
John,
You do not have to start the car. Put it in gear without the car running. Then push the clutch in and have someone try to push the car. If itmwill not roll the clutch disc it stuck. If so keepmtrying to rock it to get it free. Keep the clutch in. If that doesn't work and you don't want to take it apart you can try something else. It is not safe and can break parts. So do it at your own risk. Try jacking it up in the rear. Start it in gear and let the wheels turn. Then while you are in the car and ready on the brake pedal have some one lower the jack. When the wheels touch it should come free. You may have to do it a couple times. Again, THIS IS NOT SAFE! THERE ARE HUGE RISKS AND DOWNSIDES! DO IT AT YOUR OWN RISK! Did I mention be very very careful, it's dangerous! Have I been clear? Good luck!
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 10-09-2011, 05:57 PM
thanks for the tip.
It sure does sound like its a stuck disk. Try this, with the car off in neutral, push it out on to the drive way. Chock a rear wheel, start the car in neutral and let it run on the driveway for a good 15- 20 minutes, get it up to operating temperature to really heat soak the parts. Then get in and push the clutch in, with clutch to the floor rev the engine a few times to around 3500 rpm. hopefully centrifical force will be on your side and it will free itself.
good luck
Rich
Old 10-10-2011, 05:12 AM
Rich I'll give that a shot. Chad I think I will pass on your suggestion.
I'm not a gambling man and don't want to break something or cause further damage. Plus not looking to hurt myself either!
Before this all happened thought about selling the car, maybe it's a sign?
John
Old 10-10-2011, 06:17 AM
ccracin's Avatar
Not a bad decision! Actually I did what Rich suggested first. I could not get it loose that way. I would not have done what I suggested if it were not for a commitment I had made. It's been a while back, I think I had promised to have the car in a parade. It sat all winter here in PA and as usual I was running behind getting everything ready. I had just detailed it and checked all the fluids. I got in pushed the clutch in and hit the key. It was in 1st gear and jumped toward the garage door. Of course I had to be where I was going in an hour! Anyway after some playing I figured it was the clutch disc being stuck. I got it started and warmed up and tried burping it at all different rpm levels. No luck. So my last ditch effort was to do what I described. In my case it was not bad at all, got lucky. Got it on the jack at idle and let it down. Still stuck. Jacked it back up, got it to about 1500rpm and let it down. Bingo. If it weren't for the parade, I would not have done it. I felt like I had to explain myself, because this not something I would normally do. Now when it sits, I not only start it periodically, I engage and disengage the clutch a couple times. No issue ever since! Good luck.
Chad
Instagram - @cctek
