Old 10-23-2011, 08:45 AM
akrapovic's Avatar
akrapovic akrapovic is offline
Default 69 Camaro, Angry Pumpkin
I dropped by my motor shop and my motor is coming together. It's a procharged motor wet sump motor. I'm going to run a D1SC with the helical gear set. Mild cam so it's hopefully somewhat of a sleeper when it's idling. Wiseco pistons, K1 rods, ls7 heads with upgraded valves/springs. Fast 102 intake. Goals for boost are about 15lbs, we'll see depending on how much the motor makes on the dyno NA. Goal is 900hp hopefully a bit more. Taking a page from the ls9 and going with piston squirters. The car is a 69 camaro with a T56 from D&D. Short block is being assembled just waiting on heads. Woo hoo!!!
Just saying
Motor is done, just waiting to install, wire and plumb the d1sc/supercharger.
sub frames burner in. Cage should be done in the next week or so.
setting ride height on chassis table
BFG 345/30/18s on 18x12s
Couple of shots prior to tear down
Shock bar tacked in
Wheels before I powder coated/widened
Old 10-24-2011, 06:01 PM
tones2SS's Avatar
tones2SS tones2SS is offline
Very cool.
Looks like a great build. I like your engine specs!
Old 11-14-2011, 08:59 PM
akrapovic's Avatar
Thanks.
More pics
ladder bar cross member
Fabricated housing
Old 11-15-2011, 06:24 AM
coolwelder62's Avatar
Very Nice.Will keep watching this one.
Old 11-15-2011, 07:39 AM
jr4452's Avatar
jr4452 jr4452 is offline
Ditto!!!
JR
65 Mustang Hardtop
Old 11-15-2011, 04:47 PM
akrapovic's Avatar
Thanks guys. I'm sure many can relate but this has spiraled out of control a bit.
Fuel cell mounted
Old 11-17-2011, 11:06 PM
akrapovic's Avatar
Shock tabs plated
Had to modify the stock style DSE control arms for the coilovers. Obviously not done.
Rear bars, tin work and tubs are next.
Old 11-19-2011, 09:17 AM
66 mustang 66 mustang is offline
Very nice, who makes those wheels?
Old 11-19-2011, 03:46 PM
akrapovic's Avatar
The wheels are Intro G-Cubes
Old 11-19-2011, 08:26 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
That does tend to happen. Seems to be the biggest challenge...keeping a build under control.
Curtis
