Old 11-01-2011, 09:43 PM
usa-69z usa-69z is offline
Default clutch recommendations ?? T56 -sbc
Im looking at buying a clutch kit in next few days for my T56 conversion to early SBC,.
Ive got an 11inch 168 tooth lightened flywheel on its way , so now just to re-check .. do i need a 26 spline 11inch clutch & pressure plate kit ? I am using the concentric hydralic clutch unit,, does that matter on clutch type?
can annyone recommend one? , possibly from summit or jegs catalogue.
(my car was an auto ) round 400/450 rwhp.
Thanx, Gav
69 CAMARO - RIGHT HAND DRIVE AUSSIE MODEL.
383 SBC 8 STACK INJECTED EFI.
RIDETECH FOUR LINK REAR - DSE MINI TUBS .
SPEEDTECH FRONT A ARMS & COILOVERS.
MOSER 3.7 REAR- 6 SPEED T56 TREMEC.
FIKSE RIMS ETC ETC..
Old 11-02-2011, 09:00 AM
Swain's Avatar
Swain Swain is offline
If you are running the LT1 T56 you will need to use the pull style clutch.
Jason Swain
Build Link 68 Camaro
https://lateral-g.net/forums/showthread.php4?t=16865
Old 11-02-2011, 11:29 AM
Rybar's Avatar
Rybar Rybar is offline
I think he's got an LS T56. Gav I'm running a new Spec Stage 3+ happy with it so far.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 11-03-2011, 09:22 PM
so i need an diaphram type ? im not up on clutches at all .. its a borgwarner tremec T56 behind a 2 piece rear main seal SBC..using a concentric hyd clutch set up.
Ive had a good look thru Jegs and summit but am unsure on what to use?
Im not a racer of any sort so a good street H/D unit that ill get some wear from. I was going to use the RAM retro fit hyd bearing (78160 jegs) as well.
any recommendations?
ryan , what brand is yours?
Gav
Old 11-04-2011, 08:43 AM
Swain's Avatar
Do you know what year car the trans came out of?
Jason Swain
Old 11-04-2011, 12:24 PM
its from a 2002 aussie GM commodore SS. (your GTO)
Old 11-04-2011, 12:38 PM
Rybar's Avatar
Brand:
Originally Posted by Rybar View Post
Spec
1969 CAMARO RS
