Old 11-09-2011, 12:58 PM
MaxHarvard's Avatar
Default power steering adapter interference?
I seem to be running into a space issue with my PS pump.
I can get the Earl's adapter in place, but can't get a wrench in there to tighten it down.
I also cannot get an AN fitting over the adapter, it gets in the way of the pulley.
LS1Nova suggested I take off the pulley and see if that allows for clearance.
Does anyone have experience with this?
Btw, LS3 GM PS pump, Camaro front drive kit.
Have a pic if need be.
Thanks!
~Eric
Old 11-09-2011, 02:09 PM
dhutton dhutton is offline
I had the same problem using Corvette accessories. I ended up using a C5 power steering hose. I have seen others use just one end of that hoses to make a custom hose.
The hose only cost roughly $12 at Rock Auto if I recall correctly.
Don
Old 11-09-2011, 02:56 PM
MaxHarvard's Avatar
Hmmm.... Must have used a AN fitting for the other side then?
I have a -6AN inlet for the rack and pinion.
Old 11-09-2011, 03:14 PM
In my case it fit directly with my DSE 600 steering box. For AN you would need to make a custom hose.
I also remember Cris at JCG machined a custom adaptor.
Don
Old 11-10-2011, 09:43 AM
MaxHarvard's Avatar
Here's a photo for people to see what I'm talking about.
Sorry for the large image.
Old 11-10-2011, 09:50 AM
Here is the C5 hose. Note how long it is so that it clears the pulley.
Old 11-10-2011, 09:55 AM
cencalc6 cencalc6 is offline
PM Sent
Old 11-21-2011, 04:47 PM
MaxHarvard's Avatar
Found a free alternative....
The nut on the fitting was filed down with a rasp, not sure if Earl's recommends this, but it got the job done
