Old 12-25-2011, 07:58 PM
KSBRKTRACER's Avatar
KSBRKTRACER KSBRKTRACER is offline
Default new project / 5.3 w/doug nash 5-spd/67 camaro
Looking for some advice . I have a 67 Camaro, stock subframe, I would prefer not to cut on the floor pan (maybe unavoidable ). I want to install a 5.3 engine with a doug nash 5-speed. I have two different scattershields. Stock camaro throw out position and 62-67 chevy II position . The difference being the position of the hole for the throwout bearing arm. I think I want to install a hydraulic throwout bearing , Is this doable, Is this the best way to go....???? Eventually I want to step up the horsepower ...550 to 600 , is this the way to go. I own the 5-speed already, a Tremec doesnt fit the budget. The nash has a vasco jet mainshaft already. Is there any thing I'm missing here, any thoughts, any suggestions.
Old 12-26-2011, 08:02 AM
Another thing I havent thought about is input shaft length .....? Difference there I assume ...? Also neither of the scattershields have a mount for a hydraulic slave cylinder .... I would think it could be added , does anyone make a kit to add it or is a fab item only ? What are people using for a master cylinder and mount ? I've seen the Dse bracket . Is that the way to go ? I'm sure I am forgetting some things and I will have more questions ......Any help is greatly appreciated.
Old 01-01-2012, 12:10 PM
Anyone ever used this combo .....?
Old 01-01-2012, 11:11 PM
funcars funcars is offline
I've used a chevy doug nash with a tilton trans-mounted hydraulic throwout bearing with SBC and ford motors. The measurement from the transmission face to the clutch fingers will tell you if that would work for you.
Good luck
1970 Mach I 380 Dry Sump + lots of mods
1990 C4 Corvette 400 in solid roller
1965 Corvette - back to life some day
1970 1/2 Z28 project car
Old 01-05-2012, 06:41 PM
Anyone else have any more thoughts ... opinions or experience with this combo ????
Old 01-24-2012, 08:12 PM
Still looking for some info ....
