Old 01-11-2012, 08:47 AM
KPC67's Avatar
KPC67 KPC67 is offline
Default How do I wire the bolts on my brakes?
Hey guys, I am wanting to get my brakes put together for mock up and I was wondering if you guys wire only two bolts at a time or wire them all together? I found this picture of Rich's Wilwoods on his 69, looks like he wired two at a time.
I have the same set up as Rich, and the Wilwood instruction sheet shows the way he did it. I thought I have seen it done the other way too, am I mistaken? wouldn't it be better if they are all together?
Thanks,
Kevin Carter
Old 01-11-2012, 09:09 AM
ma73z's Avatar
ma73z ma73z is offline
Either way is fine, four at a time has no benefit over two, other than maybe looks. Just my opinion though
Matt (amateur jack stand class)
73 Camaro in slooow process
69 Firebird LS1 4l60E
70 Chevelle 402bb tko600
Old 01-11-2012, 09:19 AM
asifnyc's Avatar
asifnyc asifnyc is offline
I do 2 at a time.
-asifnyc- penngrove, ca (SF bay area) asifnyc.com - Javelin Blog
1974 AMC Javelin NASA American Iron road race car
1974 AMC Matador road race project
1975 AMC Gremlin shell
1973 AMC Javelin/AMX - street
1975 AMC Gremlin - street
1970 AMC Javelin shell
1962 Rambler American vert
Old 01-11-2012, 03:07 PM
Musclerodz's Avatar
it makes no difference if you do 2 or all of them except when you screw up, how many you have to redo. the trick is to properly wire it as there was a thread on pt.com recently over this very thing where a customer showed poor wiring technique by a shop. he promptly fixed it himself much better than the shop did it the first time.
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-11-2012, 05:42 PM
I've always done two at a time... the wire really isn't HOLDING anything - it's just there to not allow a bolt to back out...
Old 01-11-2012, 06:22 PM
Sieg's Avatar
Sieg Sieg is offline
Wiring in pairs is much easier than a series.
Note that properly done the wire holds tightening tension against it's partner.
