Old 01-29-2012, 01:24 PM
Spitfire100 Spitfire100 is offline
Default Ride Tech Air Bar Weld on Four Link Brackets ?
I am in the process of adding a Ride Tech rear Air Bar suspension on a 69 Camaro. The question I have is, I am starting with a bare housing, so I ordered the kit with weld on brackets. I noticed the leaf spring brackets on original housings are angled in to the front spring mounting brackets. Would there be any advantage to moving the weld on 4 link brackets toward the center of the housing so they would be square with the front mounting brackets. Also if anyone has had any experience with this let me know. I will also call Ride Tech in the morning to ask their recommendation.
Old 01-29-2012, 03:34 PM
coolwelder62's Avatar
Just move them in until everything line's up perfect,shouldn't need much.Ask For Darren Schilling if you call RideTech on Mon. Scott Mock.
Old 02-01-2012, 06:21 AM
Default Ride Tech weld on brackets
Thanks Scott, I also called ridetech and got the same answer, it took about an inch on each side, got them welded in place last night. I really like the weld on brackets makes for a professional looking job.
