Old 02-04-2012, 06:38 PM
The T-man The T-man is offline
Default Treating raw cast Aluminum intake, RainEx or...?
Some old timer told me that prior to install, treating a new cast aluminum manifold with several applications of Rainex would supposedly keep it from getting oil/fuel stained.
I don't want to polish it. Looking for low maintenance.
what do you guys think, or use / recommend?
thanks in advance!
Old 02-04-2012, 11:17 PM
David Pozzi's Avatar
On Mary's first engine, the 383, I sprayed some clear coat on the Edelbrock intake. It darkened it a little but it doesn't absorb oil or dirt like raw cast does. I did the cast wheel centers too because they really get coated with brake dust. I did light coats of clear, didn't build it up too heavy because I didn't want the aluminum to have a clear coat shine.
http://www.PozziRacing.com
Old 02-05-2012, 04:56 AM
Lowfast's Avatar
Lowfast Lowfast is offline
What about using Sharkhide, that should keep it protected and not change the original color.
Old 02-09-2012, 12:19 AM
anyone else?
Old 02-09-2012, 03:49 AM
oldgoat's Avatar
oldgoat oldgoat is offline
The old guy is right about Rain-x. You can also use any number of spray on clear coats. Test on another part with fuel before you commit.
