Old 02-04-2012, 09:04 PM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Default UCA hardware question
Hey Guys. I am putting my new suspension together this weekend and I am changing out the hardware to grade 8 stuff. I noticed that the bolts that the upper control arms slide on to, have splines just under the bolt head (I assume to prevent it from spinning - see attached pic).
Do I have to use this type of bolt for the replacement or will a regular grade 8 hex bolt be ok?
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 02-05-2012, 04:11 PM
badbu68 badbu68 is offline
You're correct, the reason they have splines is so the bolts won't rotate in the hole. You can use regular bolts but if you have stock upper control arms, it makes it harder to tighten down or change the alignment as you have to use two wrenches instead of just one on the locking nut side.
Hope that helps.
-Joe
Old 02-05-2012, 05:51 PM
mrr1999's Avatar
Thanks, Joe.
70 Chevelle SS396
69 Mach I
