Old 02-28-2012, 10:44 AM
bad.samaritan's Avatar
bad.samaritan bad.samaritan is offline
Default Rear Coilover question
Hi guys
I have been looking at installing some coilovers on the rear of my 70 Chevelle and was curious about the kits that are bolt in and re-use the original shock area vs. the weld-in kits.
I i'd like the ease of bolt in but I am a little nervous about all that pressure being put on that small area at the edge of the spring hat where the original shock goes. Any issues of it breaking?
Here's a install writeup of one of the kits I've considered using (thanks SicMonte!)
https://lateral-g.net/forums/showthread.php4?t=35470
Old 02-29-2012, 04:46 AM
Supporting Vendor
We use a 3/16" plate to help distribute the load, so the bracket will not "rip" through the stock mount. The stock mount is quite thick and more than capable of the job (unless you have a rusted frame). We've been doing this for years on other models and I've never seen one break.
Skunk Werks
Ridetech
www.ridetech.com
Old 02-29-2012, 09:55 AM
Thanks for the reply, my frame is pretty decent despite being a pacific northwest car. I was just curious if that had ever been a issue for people. I was looking into the ridetech kit specifically as well.
Old 02-29-2012, 09:57 AM
The Ridetech kit is a nice setup, and I think will work well for you. They have proven setups that are great for street cars and also that can perform on the track. We are also a RideTech dealer, so feel free to give us a call with questions or pricing.
Old 02-29-2012, 10:05 AM
Blake Foster's Avatar
The shamless plug is below.
have a look at the Speedtech kit also.
http://http://www.speedtechperforman...rod/prd185.htm
Blake Foster
www.speedtechperformance.com
Old 02-29-2012, 10:18 AM
Sieg's Avatar
Sieg Sieg is offline
Sincere edit below (extra http:// in original link)
http://www.speedtechperformance.com/...rod/prd185.htm
Old 02-29-2012, 12:07 PM
Thanks guys,
Here is my setup so far:
Front suspension:
Speedtech UCA/LCA
Stock spindles w/Moog Ball Joints
QA1 Coilovers
Hotchkiss front sway bar (too big will change when possible)
new bushings throughout
Rear Suspension:
GM 12 bolt
UMI Boxed LCA
Spohn Adjustable upper LCA
Moog stock springs w/crappy KYB gas-adjusts
stock sway bar
new bushings throughout.
I am finally ditching the rally's and oversized tires that came with the car for some NewGen Anarchy's and Nitto 555's and would like to be able to adjust the ride height as needed, as well as have at least a single adjustable shock in the rear. I was talking to a friend about the coilover kits and he voiced some concern that was in my original post. I'm just trying to do some homework and figure out what works best. The price for the coilover only kits seems to be about the same between ridetech/speedtech/chassiworks.
Old 02-29-2012, 07:17 PM
All of them are great choices, but since you have SpeedTech components up front, it seems natural to get their kit for the rear.
Old 03-01-2012, 05:27 AM
JustinB's Avatar
JustinB JustinB is offline
I installed a Speedtech rear kit on an A-Body a couple months ago and was very happy with the fit and quality on the kit. I would run it again in a heart beat. Speed Tech coil over kit with the Ridetech coil overs gets my vote.
Justin Butler
69 Camaro, 68 Camaro, 05 GTO.
Old 03-01-2012, 10:29 AM
I have looked at their kit and thought that they only sold QA1 coilovers for their rear coilover kit?
