Old 02-29-2012, 11:40 AM
Sieg's Avatar
Sieg Sieg is offline
Default MSD Atomic FI System - Info?
Anyone have experience with the MSD Atomic fuel injection system?
Single fuel line??
http://www.atomicefi.com/?gclid=CJ3M...FWxU4godE3-7VA
Old 03-01-2012, 03:33 PM
supremeefi supremeefi is offline
Default Efi
I just posted some facts about the MSD here
http://www.thirdgen.org/techboard/df...ml#post5199193
Scroll down, you'll see it at the end.
You decide.
Mark
Engine builder and tuner.
Old 03-01-2012, 04:17 PM
camcojb camcojb is online now
You decide.
sounds pretty limited.
Old 03-01-2012, 05:16 PM
SLO_Z28 SLO_Z28 is offline
Running a rubber fuel line the length of the car like they did in the install video bothers me.
James F.
1974 Camaro Z28
Old 03-03-2012, 08:15 AM
Bad Bowtie Bad Bowtie is offline
I've got one coming From what i understand the rubber hose is required due to what is called "hammering" if you used a steel line. I think this is caused by the fuel pump being "pulsed in rapid succession". They are marketing this as a returnless system. I am going to run steel lines and use a return system back to the tank just so i dont have to run the rubber hose. Rubber hose full length of the car doesn't do it for me
BB
Old 03-03-2012, 08:57 AM
Sieg's Avatar
You decide.
Mark - For a old school 355 that's around 400 hp with cast iron 2.02 heads what's the appropriate Accel system?
At some point the plan (economy dependant) is AFR or equivalent heads. If that doesn't provide enough grunt I'll make it a 383.
Old 03-03-2012, 07:56 PM
An Accel Thruster, #77010W. Here's the beauty of something like this and the point I was trying to make on that post.
For about $400.00-$500.00 more you get a whole lot more tuneability. And although the Thruster will do a lot, you can upgrade to a Gen 7 for the ultimate in tunability for another $400.00. It'll run anything from a 200hp TBI to a 2000hp turboed whatever. There are better systems out there for the money than that MSD. I understand it fills a niche, but for what you get it's not as good of a deal as others out there.
Jmo.
Mark
Old 03-03-2012, 08:19 PM
Sieg's Avatar
Thanks Mark.
Old 03-05-2012, 07:11 PM
You're welcome.
Mark
Old 03-05-2012, 09:55 PM
Save your money - I've got a freshly re-done set of 190 cc AFR heads on the shelf with your name on 'em....
