Old 03-08-2012, 10:40 AM
mrr1999's Avatar
mrr1999 mrr1999 is offline
Default Inner tail panel valance question
Hey guys-
I need to replace my inner tail panel valance and had a question. Since the rear frame rails are welded to it, will I need to brace them or the back of the car in general before I remove it or is it a simple remove and weld up the new panel?
Also, I am assuming to do that job, I will have to remove the rear leafs since they attach to the frame rails, right?
Since it's my first time, I don't want to mess anything up.
Thanks.
Mike - Las Vegas, NV
69 Camaro - in process
70 Chevelle SS396
69 Mach I
Yes...Chevys and Fords
Old 03-13-2012, 10:26 AM
mrr1999's Avatar
bump...
70 Chevelle SS396
69 Mach I
Old 03-16-2012, 07:08 AM
KPC67's Avatar
KPC67 KPC67 is offline
If your floor pan is still in I can't see them going anywhere laterally, so I don't really see the need to brace them.. How much of the car do you have apart?
Kevin Carter
Old 03-16-2012, 04:11 PM
mrr1999's Avatar
Lots of it. Trunk floor is out and I will be replacing the tail panel. So at some point, the entire rear will be gutted short of the quarters.
70 Chevelle SS396
69 Mach I
Old 03-16-2012, 06:38 PM
hud697's Avatar
hud697 hud697 is offline
I'm no expert, but i replaced my trunk pan and welded it to the frame rails before i cut the rear valance and tail panel off. Seemed like there would be no way for them to move that way.
Overkill is an often underrated achievement.
1969 Camaro - work in progress
2011 Camaro 2SS/RS A6
