Old 03-11-2012, 03:00 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Anyone take apart a Flaming River tilt column?
With my car being a 68, quite a few of the parts are one year only. I decided to use the original steering column brackets but I had to weld the bracket to the column. When I welded it on, I tried to be careful and cool it down right away, but it started smoking. I want to pull the column apart and make sure that I didn't melt the wiring or anything. Has anyone pulled one of the columns apart before and is there anything that I need to watch for before I attempt it? Thanks in advance.
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
