Old 02-27-2006, 08:24 AM
RickM415 RickM415 is offline
Default Injector Size
Ls1
Twin Turbo 9-12 Ps1 Max (for Now... This Summer Lol)
6 Speed
3:31 Gears
....will Ford 42 Lbs Work ?
Old 02-27-2006, 08:32 AM
XcYZ's Avatar
XcYZ XcYZ is offline
No, too small.
A simple injector lb/hr equation is:
(HP) x (BSFC)/8cyl x .8 duty cycle = lb/hr
In your case: (800 x .6)/(8 x .8) = 75 lb/hr
You'll want around a .6 BSFC with a boosted motor.
My LS7 69 Camaro
Old 02-27-2006, 11:48 AM
Blown353 Blown353 is offline
Scott has the math right, but I always like to be conservative and I figure a .65 BSFC for boosted applications. I had to buy injectors twice (underestimated the HP, lol) and lost $250 on the ordeal of selling them and buying new ones, so that's my reasoning for being a bit more conservative on the calculations.
I'd say 75 or 83 lb/hr injectors would be the way to go.
Troy
1969 Chevelle
