Old 04-06-2012, 07:47 AM
garickman garickman is offline
Default Do I need trailing arms on my custom IRS chassis?
Greg
Old 04-06-2012, 08:08 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Greg, now I'm no expert, but I would assume not. It's an IRS. Why did they say it needed trailing arms? New cars, Vette's, Vipers, etc with IRS don't have trailing arms and my frame won't have any either. Don't think the Roadster Shop IRS chassis's uses one either.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 04-06-2012, 08:56 AM
Jr's Avatar
Jr Jr is offline
That IRS looks good!
Old 04-06-2012, 09:11 AM
65_LS1_T56's Avatar
65_LS1_T56 65_LS1_T56 is offline
Default trailing arms?
I'm seeing it needs more direct attachment to the frame (the center section). Right now, it looks as if it is "hanging" only from the frame. You have to imagine all of the twisting force that a rear sees, live axle or independent. To me, I think you need a whole other "cradle" that the rear kind of sits in as well as the upper attachment you currently have. Maybe you have plans for that, but not shown yet.
Also, most independent style rears would have a toe link too. Unless you are going for something like the Heidts system. Notice the "trailing arms" on theirs and the cradle under the center section.
Also, how do you adjust for caster?
Fab work looks great.
Aaron
65 Chevelle
Project G-Velle
66 Corvette, Spirit of '66
Project G-Vette
Old 04-06-2012, 09:45 AM
214Chevy's Avatar
Correct...mine will have that.
Originally Posted by garickman View Post
What exactly is a toe link?
Greg, 65 LS1 T56 is correct about the toe link. Toe link bars are what will attach to the steering arm portion of your spindles. Which would be the equivalent of what the rack and pinion attached to on your front spindles. I've included a pic of an RS chassis with the toe link bar circled. Toe links or bars help with your cast when aligning the rear wheels and dealing with cast and camber.
'68 C10 swb
'72 Chevelle
Old 04-08-2012, 06:19 AM
65_LS1_T56's Avatar
I'm assuming Ironworks was referencing me as "some guy on the internet" even though we all are just that...my post was:
Also, most independent style rears would have a toe link too. Unless you are going for something like the Heidts system. .
He is also correct, it is called a toe link, not a "Tie Rod" in the rear.
a simple diagram of an independent rear, though different in design than the Jag style.
I do agree that Greg should just trust his chassis builder as well. The work looks great.
So thats it from someone on the internet who has no idea.
Aaron
65 Chevelle
Project G-Velle
Project G-Vette
Old 04-08-2012, 08:59 AM
ironworks's Avatar
Exactly, You might be the lead chassis designer for Chip Ganassi racing for all I know, No one has any ideas who is who, REALLY. All we have is screen name and a cool little picture. There are tons of guys who have been here for a while that we all find out are snakes in the grass years later. But my point is when you open up your project for the masses opinions, Your getting exactly what you asked for. The same idiots we share the road with, the same idiots who voted opposite as you, same people who do ugly things to certain cars that we like. There are tons of internet no it all's that have no idea about anything and once in a great while there might be a smart guy who gives you his opinion and all the know it all ponce on him. I did not mean any body in particular with my comment.
I really think these posts are a waste of time in the fact you cannot tell much from 3 pictures. And even if you could what is that going to prove when you go tell the guy doing the work what someone on the internet said. Pictures maybe worth a 1000 words but they give you no idea what is really going on during construction of a project, you have no idea what is what without really talking to the mastermind behind the project. Just like the saying goes you can't judge a book by it's cover, you also can't judge a project until it's complete.
I have never in my entire life heard the term toe links, So I guess I learned something new today. I wish you well on your project as I have heard you have had a rough go, but all I can say is you have to be on top of things or the same thing can happen again, don't trust anybodies work. Ask questions to be educated by the guy doing the work and keep asking until it all makes sense, if it does not make sense go ask some one smart who is willing to get involved. In a project car you connected to a guy for a long time with the quality of work they do. If you unknowingly pay for junk it will be with you until you cut it out and it will never be what it could have been. Picking a builder is like picking your wife, you better know exactly what your getting into. Because your going to be stuck for a long time with the person.
Old 04-06-2012, 09:47 AM
Vince@Meanstreets's Avatar
Toe link is a bar that runs from the stationary section of the frame. Its to adjust rear toe on IRS, but since this is a Jag style LCA set up it should not be necessary.
The LCA appears to be attached to the steering arm mount on the ATS spindle. If the LCA was designed with a lower ball joint then you would need a toe link to keep the spindle from rotating.
The builder is the best person to ask. He's knows what he is doing.
thanks 509...I type slow. LOL
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 04-06-2012, 09:54 AM
On the trailing arm comment as related to the rear section (I assume he means differential). you should be fine, the diff mounting looks beefy enough as full rotational torque forces are not transfered through the half shafts.
Dealer for
NEVER FORGET -11
Old 04-06-2012, 01:03 PM
65_LS1_T56's Avatar
yeah, I meant differential (the whole center that is fixed to the chassis). Greg mentioned another attachment that is not shown yet, I'd like to see that before changing my mind. You'll notice the lower differential to frame mounting on the Heidts as well.
The toe links are not required in this setup after I thought about it since it does not use a lower balljoint, so that additional degree of freedom is removed already.
Not sure how adjusting the upper single link would affect caster though, camber yes. The lower control arm mounting points on the knuckle would have to change too, right? Maybe it will just be set and fixed at a number?
Love the rocker arms though, that is very cool. Hopefully you put a "viewing window" in the floor pan to see it
Aaron
65 Chevelle
Project G-Velle
Project G-Vette
