Old 04-10-2012, 08:24 PM
suark's Avatar
suark suark is offline
Default T56 Magnum reliability with dual disk clutch
I've read/heard more than once that the stock syncros in the t56 don't last long with a dual disk clutch due to the additional rotating weight they have to deal with. Has anyone been running a t56 with dd clutch and had any problems? Rockland says I'll need their trans if I want to run a twin disk.
1968 Camaro
Build thread: https://lateral-g.net/forums/showthread.php4?t=36348
Old 04-10-2012, 09:22 PM
James OLC's Avatar
I've run my T-56 magnum with a dual disk clutch for almost three years now and have no issues. Started with an aluminum flywheel and now running a lightened steel piece from Centerforce. I would hazard to guess that the dual disks that I have run have been lighter than stock so I don't know if that's a legit justification but I am not sure.
James
1967 Camaro RS - The OLC
1967 Camaro RS - Recycler
1969 Camaro - Dusty
Old 05-17-2012, 05:06 PM
1 Dwn Cam's Avatar
1 Dwn Cam 1 Dwn Cam is offline
While it's true that the larger the diameter of the disc is spinning outside the centerline of the crank the more work it takes the synchros to slow down and cause havoc on the synchros, i personally think its a sales pitch to sell a umpteen thousand dollar transmission. Thousands of people use twin disc units on T-56's from 93-02 camaros and 2003-04 cobra's all the time.
This will give you an Idea.
http://www.cardomain.com/ride/2368130/1
Vrbancic Brothers Procharged 406
781.5 HP @ 6500
701 @ 5500
14 psi.
Old 05-22-2012, 12:13 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
My newish Mustang has a tr6060 with a dual disk clutch from the factory, if that says anything. I've been running the same clutch James has for the last year in my Camaro, and no issues either.
Matt
Old 05-22-2012, 10:44 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Originally Posted by suark View Post
..... Rockland says I'll need their trans if I want to run a twin disk.
...yeah I just bet you absolutely, positively, cannot drive your car without theirs. While Rockland does make a good tranny, no doubt, but the stock T56 magnum will do just fine with a twin disc. Although I haven't driven mine yet, I'm running mine with a dual disc Ram clutch.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
