Old 04-26-2012, 11:39 PM
John510's Avatar
John510 John510 is offline
Default Anyone running solid mounts?
I finally found some 2" setback plates but they are solid (well they have the poly ones but they sit the motor too high)
Am I going to regret going solid mounts on a twin turbo wild cam car?
http://dirtydingo.com/store/Muscle-C...306/index.html
[SIGPIC][/SIGPIC]
Old 04-27-2012, 09:43 PM
tiznodd's Avatar
tiznodd tiznodd is offline
I have solid mounts on my turbo LS and didn't notice any increase in vibration. I do have a mild cam though...
67 Camaro. LQ4/T56 w/Precision 7675 turbo.
Old 04-28-2012, 07:38 AM
dhutton dhutton is offline
It is my understanding that solid mounts will cause false hits on your knock sensors.
Don
Old 04-28-2012, 11:31 AM
Rybar's Avatar
Rybar Rybar is offline
I'm running solid mounts as well. I didn't notice much of a difference either. Also, make sure you run a poly trans mount I have heard you can crack the tranny case tailshaft if you run all solid.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 04-28-2012, 01:40 PM
John510's Avatar
Thanks guys. Ill try the solid.
By using the solid I get that extra 1/4" drop down on my motor. I really need that so my manifold clears the hood.
[SIGPIC][/SIGPIC]
Old 04-28-2012, 01:52 PM
With twin turbos, I really think you will need solid mounts. Poly or Rubber will give way eventually.
Old 04-28-2012, 08:36 PM
steinepstein steinepstein is offline
Question for my general knowledge...aren't you stressing the block by running solid mounts? I thought you wanted the motor to be able to "flex" or have some amount of movement. I've heard of a lot of sprint blocks cracking due to solid motor mounts.
Old 04-29-2012, 05:54 PM
David Pozzi's Avatar
Don
I heard the same thing.
http://www.PozziRacing.com
Old 04-29-2012, 11:34 PM
Maybe run a solid on the drivers side and poly on the passenger side? I have a solid on the drivers side and rubber on the passenger and the engine moves to much for my taste.
Old 05-01-2012, 05:44 AM
What if you had either a front or mid engine plate that had poly mounts at the frame mounting points? This would significantly decrease the moment and still provide dampening.
