Old 04-27-2012, 05:21 PM
medbali76 medbali76 is offline
Default anyone using Bolt-on front Coil-Over-Shock conversion for early Mustang and Cougars?
I am thinking on a Coil-Over-Shock conversion for my 69 Cougar.
Since my roller control arms and the adjustable strut rods are brand new (from Opentrackerracing) I dont want to buy a complete new front suspension.
I found a conversion at Total Control Products but I dont know how good is that system compare to the "full" Coil-Over conversion systems.
This is the coil-over shock I am thinking on.
Does anyone have experience with them?
[IMG][/IMG]
Old 04-29-2012, 02:47 PM
Bryce Bryce is offline
I designed and built my own version of that. I wanted to use an AFCO shock and I wanted to use a longer stroke on my shock. But the concept is similar.
Function of that setup should be just fine, but a good shock and spring will do about the same. except for adjusting spring preload.
What are the goals for the car?
Old 04-29-2012, 11:19 PM
Actually I just want a superior handling car on the street which is able to go and perform good on the track as well. It will be used mostly on the street. My wife does not like the "dump truck" feeling so that is why I was thinking to go with adjustable front set up.
Old 05-01-2012, 04:22 PM
Chassisworks Chassisworks is offline
Supporting Vendor
TCP is a Chassisworks brand that deals exclusively in Ford muscle components. This kit was developed as an economical alternative to our TCP FCOC-FD kit.
One of the cool things about this kit is it will fit your stock arms AND, should you choose to upgrade later, our double adjustable upper arms. You can dress it up a little bit under the hood with our optional polished billet stainless steel cap. It hides the grease zerk. There are two different ride height ranges available and a large selection of springs.
We also make the same product for a Chevy-II. In fact, Church Boys Racing uses it in their Nova kits. Here's some links to check out a ride review and some video.
1962 Nova Wagon Article Here and Video Here.
1963 Nova Article Here and Video Here.
You can find a lot more specific information at the links below. Or you can just call us, or me directly, on the phone.
Technical Data Sheet
Installation Guide - Shock
Installation Guide - Mounts
~Carl O.
Old 05-02-2012, 10:19 PM
~Carl O.
Thanks for the information
