Old 05-07-2012, 09:04 AM
orangevert's Avatar
orangevert orangevert is offline
Default Lokar DBC, LS1 What length will I need.
Im almost ready for throttle cable, What length did you run? Did you use your factory pedal or did you use a diferent pedal?
Thanks Guys, I strugle to ask stupid questions, But the knowlege o
n here helps me from buying the wrong stuff
Thanks again Kirk
Kirk
67 Convertible LS7 BBC 542HP.540 TQ
400 Turbo, 12 bolt posi, 13"12'' CPP Disc, Hotchkis connectors, belly pan.. Hush matt. 3" mandrel bent and load of other stuff.. More a show an Go..
Old 05-07-2012, 09:29 AM
dhutton dhutton is offline
I used the stock Camaro 6 cylinder pedal. The Lokar cable is cut to fit.
Don
Old 05-07-2012, 11:19 AM
brownz brownz is offline
I just installed a lokar cable on my 79 and I did not have to cut it. I think it was a 36in cable. But not sure if you will need a different lenght for a first gen or not? I also used my stock pedal and will be installing the MODO covers.
Old 05-07-2012, 05:42 PM
I dug up the part number of the lokar cable that I used. Its a TC-1000LS1. It is a 36in cable. I would look on amazon if you dont have one yet, that is the cheapest place that I found it and with free shipping.
Old 05-07-2012, 06:06 PM
1HTBRRD's Avatar
1HTBRRD 1HTBRRD is offline
I used the 36 inch lokar cable, stock 69 pedal, and had to trim the housing and cable....but it was very easy and could probably be left alone, I was just a little anal about it.
1962 Nova, LS1/ T56, DSE Mini tubs and subframe connectors, Church Boys 4 link, Viking coil overs, C6 brakes
Old 05-08-2012, 01:21 PM
orangevert's Avatar
Thanks for the info brownz
Kirk
