Old 06-01-2012, 05:02 AM
67mike 67mike is offline
Default What Steering joint to use? 67 Camaro
I completly removed the front subframe bushings on my 67 Camaro for a lower stance without losing header clearance. Now the stock steering shaft does not line up correctly. There is too much of a angle for the stock rag joint, so I need a double U-joint.
What double u-joint will best fit my facory manual steering shaft?
Has anyone done this?
Thank you
Old 06-01-2012, 11:15 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
This may be your best shot.
http://www.borgeson.com/
You may have to make a new plate for the firewall and run a swivel mount http://www.borgeson.com/xcart/catalo...-p-1-c-53.html then a single swivel joint. That will also raise the steering wheel so a tilt column will help or shim the column down at the dash to compensate. Or you could run one of these and do what ever you want for column angle http://www.wizardsteerclear.com/
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 06-02-2012, 09:56 AM
Rybar's Avatar
Rybar Rybar is offline
You will have to measure the shaft and splines on the steering column end and steering box end. There are quite a few different sizes/splines.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 06-03-2012, 11:32 AM
Vince@Meanstreets's Avatar
Thank you
We also modify the firewall steering shaft mount to work correctly.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 06-12-2012, 01:51 PM
I guess im a little lost on this now. I have done some research and it seems that a double u-joint would be too long to fit in between my firewall output and the stock steering box.
Are you guys using rack and pinions when removing the bushings?
I assume I will need a double u-joint to get the angle right?
I didnt think this would be so hard.
