Old 06-07-2012, 05:49 PM
Blake Foster's Avatar
Default Speedtech Second Gen Torque Arm
Well it has been a bit of a wait, Speedtech now has 2 versions for the 70-73 and 75-81
3" exhaust over the rear end is not an issue. 345 tires with NO FLOOR CUTTING. mini tub required obviously. ride height as low as the tire to fender well will allow. sa with the firs gen the only welding required is the rear shock cross member.
price with QA1 shocks is 2199.99 ridetech shocks are 250.00 upgrade.
Blake Foster
www.speedtechperformance.com
Old 06-07-2012, 06:02 PM
Gorgeous love the cut outs..
Old 06-07-2012, 07:13 PM
Firebirdsteve's Avatar
Firebirdsteve Firebirdsteve is offline
That is sweet.....I'll have to get me one of those set up's!!!
1981 Pontiac Firebird
Build by Speedtech Performance
http://www.speedtechperformance.com/...rod/prd287.htm
Old 06-07-2012, 09:33 PM
Ron in SoCal's Avatar
Better hurry up Steve or someone will beat you to it!
Nice job Blake!
Ron in SoCal
69 Camaro in progress
Old 06-08-2012, 02:59 PM
DEIVIONCRX's Avatar
DEIVIONCRX DEIVIONCRX is offline
Available for the 10bolt?
1980 Formula
1980 Indy Pace T/A
Tech and Services at Deatschwerks
Old 06-10-2012, 12:22 PM
coolwelder62's Avatar
Wow!! Very Well thought out.Everybody come's out w/the neat stuff after I spend hour's in the garage trying to build my own junk.
Old 06-10-2012, 01:07 PM
SLO_Z28 SLO_Z28 is offline
For that price it comes with the 9 inch housing? Can you use the 10 bolt? Why no 74?
James F.
1974 Camaro Z28
Old 06-10-2012, 09:40 PM
No 9" Housing for the 2195 price if you want a complete bolt in 9" with Strange 31 spline axles S case any gear ratio, brackets welded on fully assembled it is another 2995.00 710.00 if you just want the housing.
10 bolt is a posibility yes have to get to making some pinion mounts but other than that we can do a 10 bolt
Typo on the available years 74 seems like a bit of a bastard year as that is when they changed the floor pans. so either way we can do it. probably need a picture of the pan to verify which X memeber to send
Blake Foster
Old 06-11-2012, 07:14 AM
DEIVIONCRX's Avatar
Very good. I'm still in the rust repair part of my build but i eventually planned on some sort of Torque Arm rear, BMR's pretty much the only option for a prebuilt setup right now.
1980 Formula
1980 Indy Pace T/A
Old 06-11-2012, 07:55 AM
WERE....... past tense
Blake Foster
