Old 06-09-2012, 11:15 AM
Bluesman1's Avatar
Bluesman1 Bluesman1 is offline
Default LS1 v Aftermarket brakes
Ok guys I need some input on LS1 v Aftermarket brakes on my 70 chevelle, I have read several articles on converting over to LS stuff. I can see one advantage to the LS stuff, for starters if something breaks on the road you can go to just about any auto parts to buy replacement parts. But you don't have the show appearance of the aftermarket brakes. But if I go with LS stuff I will have to switch from my 15" wheels (which I really want to keep) to 17's or 18's. If I go with say wilwood 12.19 brakes I can keep the 15's. So I thought I would make a post for input, I'm trying to make up my mind as to which way to go. I know the LS route would be more economical as far as brakes go but the money I save there will not even cover a 1/4 of the expense of the wheels and tires to upgrade. Anyways thanks for any help in advance.
Howard
Old 06-09-2012, 09:30 PM
instro84's Avatar
instro84 instro84 is offline
Default ls1 brakes
depends on what you want brakes for, if you want them for performance ls1's are pretty good i have them on my turbo buick that runs low 11's in the quarter, was a cheap and simple upgrade i run 16 inch wheels thou.
Old 06-09-2012, 11:25 PM
Bluesman1's Avatar
Cool thanks for the response.
Howard
Old 06-10-2012, 10:50 AM
hifi875's Avatar
hifi875 hifi875 is offline
I have them fr and rr and they work good. If u clean em up and paint the calipers and rotor hats they will look as good as anything else
Old 06-10-2012, 02:23 PM
SLO_Z28 SLO_Z28 is offline
It sounds like you want them for the looks, in that case the wilwood D52 calipers are a slight downgrade from stock but they look great and are a direct bolt in allowing you to keep your current wheels.
James F.
1974 Camaro Z28
Old 06-10-2012, 10:19 PM
rixtrix1's Avatar
rixtrix1 rixtrix1 is offline
Default Depends on all the factors.
Howard
If you don't mind changing to larger wheels and can fab the hubs and brackets yourself, you can convert to LS1 brakes for under $300( not counting the wheels and tires!). Otherwise, to keep the 15" wheels, it's gonna cost more to buy a pre-fabbed brake kit. Lots of options going this way.
They work fantastic on my S10, but I have 17's on it. Haven't tried my stock 16" ZQ8 wheels to see if they will fit, but I think it will be very close.
Ric
2002 S-10, Daily Driver and autoX
1966 Chevelle MALIBU ( mine since 1971) Drag car converting to a track car!
Old 06-11-2012, 08:37 AM
214Chevy's Avatar
214Chevy 214Chevy is offline
Howard, I say keep the 15's and go wwith the Wilwood's. The price of tires and rims will far outweigh the price of buying a ready made kit from Wilwood. But, in my honest opinion I like Baer Brakes better myself as far as looks and function. Their new T4 kit is the shyza!! ANd there are many vendors on here with good prices too. I'll give you a call later.
'68 C10 swb
'69 Camaro convertible
'72 Chevelle
Old 06-11-2012, 08:58 AM
hifi875's Avatar
heres mine!
Old 06-11-2012, 02:26 PM
Bluesman1's Avatar
Sounds good Marcus
Bluesman1's Avatar
Thanks guys for the input.
Howard
