Old 06-11-2012, 06:32 PM
Bakaruda's Avatar
Bakaruda Bakaruda is offline
Default 1978 Trans Am WS6 for Sale
This vehicle is located about 30 miles southeast of Phoenix, Arizona. I began this project about 7 years ago, and it stalled. Most of the parts to finish it are there, but I do not have the time to complete the venture. The body needs some attention, but has little rust due to the Arizona climate. I have all the receipts for the parts for the vehicle. The title is clean, and I even have the original factory build sheet for the vehicle. An overview of the project is below. Asking price for the project and all parts is $10,500. I am willing to sell the parts individually upon request and if possible. There are also more pictures available. Email me with any questions and offers at [email protected].
Drivetrain and under hood:
  • GM performance fully dressed crate 502 with long water pump, Speed Demon 650 carburetor, Edlebrock heads and intake, and HEI distributor with high performance spark plug wires
  • Jet Hot coated long tube headers with 3" collectors
  • New Becool aluminum radiator and electric fan kit
  • Jegs rebuilt alternator
  • New March Performance serpentine belt system
  • Hughes Performance rebuilt TH-400 able to handle 650 HP with 9” 2700 stall converter
  • Rebuilt differential with a 3.73 posi and new bearings and seals
Fuel delivery
  • Complete Jegs braided stainless steel fuel line kit with fittings and clamps
  • Complete Jegs fuel pump kit with 130 gph pump, competition filter, fuel pressure regulator, fuel pressure gauge, and Painless fuel pump relay kit
  • New fuel tank and sending unit
Electrical
  • Painless body harness for ’74 and later GM F-body
  • Complete set of OE style wiring harnesses for engine and body
  • Electric speedometer and harness kit
Steering and suspension
  • Rebuilt P/S gear box with new pitman arm
  • One Jegs and one Napa rebuilt P/S pumps
  • New idler arm and steering linkages. May need a new center link (bent) and a couple of boots
  • Global West tubular upper and lower control arms with polyurethane bushings
  • Completely new front and rear suspension with 2" drop spindles in the front and 1.5" drop leaf springs in the rear.
  • Added sub frame connectors to strengthen body. They need to be welded or bolted into place
  • OE snowflake rims
Brakes:
  • Rebuilt power brake booster, master cylinder and all new steel brake lines and rubber hoses
  • Rebuilt calipers
  • New rotors and drums
  • New front and rear hardware and wheel cylinders
  • New pads and shoes
Miscellaneous:
  • Complete body bolt kit
  • Shaker hood
