Old 07-01-2012, 07:14 AM
snappytravis's Avatar
Default Body panel alignment
I have 69 camaro and reworked all the trunk to qtr and door edges,(welded to make fit nicely) My question is does anyone have a good idea of putting pins through door hinges and fenders that could be welded in permanetly to help for reassembly after car is painted? I was thinking of drilling 2 holes in door hinges on the body side and putting 1/8 round pins in them then welding on the outside of hinge, then when reassembly comes around just line up the pins and everything should go right back into place, any good suggestions would be appreciated. thanks
Old 07-01-2012, 05:50 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
They "should" line back up, but they don't always.
I just drill a hole, to get me in the ballpark. Just get a good helper and you'll get it lined back up.
Old 07-02-2012, 01:34 PM
jr2226's Avatar
jr2226 jr2226 is offline
X2 spent a lot of time drilling for ailment holes. with metal and mud work done and still had to make changes for final assemble.
SIKNSS AND THERE IS NO CURE!
CHEVY HIGH PERFORMANCE COVER . http://www.nastyz28.com/forum/showth...ghlight=siknss https://lateral-g.net/forums/show...project+siknss
Old 07-03-2012, 08:45 AM
so nature of the beast, no easy way out, lol
