Old 07-04-2012, 05:59 PM
patriot68 patriot68 is offline
Default how to remove water spots
ive got a set of budniks and cant get the water spots off. ive tried polishing them and using window cleaner. whats the secret??
scott
1968 Camaro, LS1/T56,martz chassis,19x10/18x8 Budniks,245/45/18,295/35/19 {Sold}
http://www.fquick.com/patriot68
1971 Firebird - Speedtech Extreme Subframe/Torque Arm, LS3/4L80E, 19x12/18x10 Budniks
Old 07-05-2012, 04:48 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
How are you polishing them?
Those can get nasty, and will need a little more elbow grease.
Old 07-05-2012, 07:29 AM
67ragtp 67ragtp is offline
Im assuming your Budnik wheels are polished alluminum. I use Wizards metal polish on mine. Its a cotton fiber impregnated with there polish and Ive found it to be the least abbrasive of many alluminum polishes Ive sampled. Should remove all the oxidation and water spots, buff to a high polish with turkish cotton cloths.
http://www.toolrage.com/prodview.asp?sku=WIZ-11011
Rich
Old 07-05-2012, 09:36 PM
elbow grease is the answer. i assumed the chip foose powerball special would work. tossed it and used my hands. thanks for the replies
Old 07-05-2012, 10:28 PM
Sti_Guy's Avatar
Sti_Guy Sti_Guy is offline
White vinigar and water 50/50 will take off hard water spots.
Old 07-06-2012, 04:19 PM
Darrell Darrell is offline
Don't use Window cleaner,dulls the aluminum ,ammonia in window cleaner is not good to use on aluminum.
