Old 07-17-2012, 11:30 PM
Hondo78 Hondo78 is offline
Default Running E85 with 11:1 pistons in 289
Reading about alcohol burning race engines, and about to rebuild my Hi Po 289 with 11:1 compression ratio.
I need to buy a carb anyway, and hard lines are a given, however can I run 11:1 compression ratio with a mild cam in a 289 and not have knocking issues. Seems like this would be fine with anything over 50 50 Alcohol fuel.
Anyone doing this?
Old 07-18-2012, 12:09 AM
KAA's Avatar
KAA KAA is offline
If you're going to run E85, you can go even higher on the compression.
You can get away with 11:1 on pump gas. 50/50 ethanol/gas no problem.
Keith
'70 El Camino SS L78 396 - It's back!
Lateral-g Feature
Chevy High Performance Feature
'09 Viper SRT-10X
Car Craft 2009 RSE Winner
Car Craft Feature
NARRA Road America TTU Record Holder
Old 07-18-2012, 07:42 PM
badmatt's Avatar
badmatt badmatt is offline
Hell we just started doing baby tugs last week with my motor 12:1 compression and pump gas.
e-85 will work.
Old 07-19-2012, 12:13 AM
Default e85
Thanks, I had run pop ups in a Ford engine several years ago when we could buy Sunoco 112 in California. I see alcohol race series engines running 180 more Hp per 350 cubes running e85.
Is there any issues with letting the car sit through the winter with e85 or must it be drained and flushed?
Also do you buy the alcohol by the drum delivered? I see you can even buy it on Amazon.com for about $2 /Gal (I might need to replace the 16 gal tank with a 20 gallon)
Old 07-21-2012, 06:06 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
You're going to buy drum'ed fuel for a 11:1 engine? Sounds like a real pain to me.
I'd avoid E85, and just run the highest octane you can get. Retard the timing some if need be.
Old 07-21-2012, 08:11 AM
NOPANTS68 NOPANTS68 is offline
Put some 12.5:1 slugs in it if you really want to take advantage of E85s edge over normal pump gas. It's by far the best fuel I have ever used and it was 2.97 a gallon last night!
1929 Roadster Pickup
1961 Chevy Parkwood Wagon
1956 Chevy 210
Smithcraft Collision and Restoration
Newcastle , CA
Old 07-22-2012, 09:37 PM
KAA's Avatar
KAA KAA is offline
Link??
Keith
Lateral-g Feature
'09 Viper SRT-10X
Car Craft Feature
Old 09-09-2012, 10:35 AM
gnx7's Avatar
gnx7 gnx7 is offline
In the LS style engines people are running 14:1 with e85. Aluminum heads help with detonation and big cams help too.
e85 for boost is amazing. 106 octane for pump gas prices.
