Old 07-28-2012, 06:39 PM
67autocross 67autocross is offline
Default Kore 3 Rotors fitment
I just picked up some Kore 3 brakes for my Dodge Dart that uses Mustang II front spindles. The first thing I went to mock up was the rotor to the hub, if you look at the picture there is no way it will fit over the wheel studs. Has anyone had any problems with these?
Old 07-28-2012, 06:41 PM
Spiffav8's Avatar
Spiffav8 Spiffav8 is offline
Lateral-g Moderator
Call Kore3. They will take great care of you!
Curtis
Old 07-28-2012, 08:09 PM
Don't take this the wrong way but the adjacent holes look to be in perfect position. I'm assuming you already tried that though.
Old 07-28-2012, 09:10 PM
FETorino's Avatar
FETorino FETorino is offline
or not
Rob in SoCal
Old 07-28-2012, 10:08 PM
Off course...
Old 07-28-2012, 11:47 PM
camcojb camcojb is online now
Pretty sure the Darts up to 73 or 74 had that oddball 5 on 4" b.c. which is too small for those rotors. They look to be for the normal 5 on 4.5" and 5 on 4.75". You'd either need different rotors, or have the hubs re-drilled. I'm thinking the hub re-drilling will be the only way to go, because there can't be many rotors in that small bolt circle.
Old 07-29-2012, 05:55 AM
Both the hubs and the rotor came from Kore3 , I ordered it with 5 on 4.5" so that I could have the bigger bolt pattern. I checked the hub and it matches up with a 5 on 4.5' wheel so I'm guessing the rotor they use must be drilled in house and it is drilled wrong.
Old 07-29-2012, 07:31 AM
Yeah, you'll need to call Tobin on that one. He's a good guy, I'm sure he'll know what's going on.
Old 07-30-2012, 07:08 AM
Apogee Apogee is offline
Give us a call or shoot us an email and I'm sure we can get it sorted out, whatever the issue may be.
I sent you a PM with my contact information since it looks like you didn't buy these direct from us.
Tobin
KORE3
www.kore3.com
Old 07-30-2012, 03:03 PM
From the top...
