Old 08-13-2012, 10:09 AM
BANKO's Avatar
BANKO BANKO is offline
Default Custom steering stops for 1965 Chevelle
Wondering if you guys have some suggestions on how to achieve this? I'm runing wider than normal positive offset wheels on the front and need to limit the steering angle. My first thought would be to use a threaded sleeve + a bolt into the frame near pitman and idler arms.
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
Old 08-13-2012, 02:52 PM
The WidowMaker's Avatar
internal stops would seem to be the best. not sure what box youre running, but you could try it yourself or ship it to tom lee.
"The WidowMaker"
Old 08-13-2012, 09:52 PM
DEIGuy38's Avatar
DEIGuy38 DEIGuy38 is offline
You could fab something up on the lower a arms to work with the steering arms
Guy
68 Camaro, LS1 T56, DSE Speed Kit 2, DSE Quadralink, DSE Mini Tub, Forgelines, Vintage Air, Dakota Digital, GM Tilt Column, Corbeau Seats
2012 Dodge 3500 4x4 6.7L Diesel CCSB
Old 08-14-2012, 05:38 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
That's what I'd look into. Just ad thickness to the factory stops.
Old 08-19-2012, 01:48 AM
BANKO's Avatar
I'm running a Lee box, but my wheels are stuffed in the fenders and I'll be going with wide positive offset wheels. I don't think the internal stops are enough. Since I just installed the box today, need to see how much angular displacement the quick ratio box has. Overall the steering is a big improvement with the box and a Sparco wheel. Trying to fit 10.5" wide in the front. Good idea on adding a component to the lower a-arm.
Josh
Old 08-19-2012, 08:02 PM
Roadbuster's Avatar
Roadbuster Roadbuster is offline
When I did my measurements for my wheels they turned a bit more with the engine on and the power steering hooked up than they did with the setup off.
Jon U.
1968 GTO - SC&C's suspension
1967 911 - a few modifications
