Old 02-08-2005, 08:40 AM
trapin's Avatar
trapin trapin is offline
Default Some small updates...nothing huge.
I installed some DS&E parts on my car about a week ago. They are the 3" drop springs and their mono to mulit-leaf conversion kit. I'm quite happy with the springs, if you remember...I was having some problems with the Hotchkis springs I had on there. The car had about 5.75 inches from the top of the tire to the bottem of the wheelhouse lip. Now with the DS&E springs it has about 3.5 inches. Don't know how much of that will be eatin' up with the weight of the drivetrain and back seat loaded on it but I'm guessing I might need to do a 1 to 2" spacer eventually. I have some before and after pictures.
Before
After
Mono to Mult-leaf conversion kit
Tony Rapin
The Pigeon Forge Project
A 1968 Pro-Touring LS1 Camaro.........and why not?
Old 02-08-2005, 08:49 AM
Rick Dorion's Avatar
Rick Dorion Rick Dorion is offline
Nice, Tony.
I'm assuming weight will help(?). I just put Global West leafs in which are stated to give a 1 1/2" drop. My tire top is just tucked into the wheel well. As this is on a 69, are the openings on yours more rounded, giving more of a gap?
69 Camaro therapy program, 410, M22! SOLD
68 Camaro - SOLD
67 Bel Air - Hmmm.
Old 02-08-2005, 09:07 AM
68protouring454's Avatar
Default rick
sorry to butt in, but yeah 67-68's have a round wheel well, where as 69's have a straight cut off wheel well, which helps so much in getting the tire above the 1/4 lip, without channeling the lowest you can get a 68 is like steilows red witch, which has an awesome stance and if i end up with anything close to that i will be pleased.
jake
Old 02-08-2005, 09:09 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Trapin,
Do you want to sell the Hotchkis leafs?
Old 02-08-2005, 09:35 AM
Y-TRY Y-TRY is offline
You may have already seen my pics, but here's my '68 with Hotchkis springs, 1" blocks and a 285/40/ZR17 on 9.5" rims...... The rear is a bit longer than stock so I have 6.25" backspacing on there. This is about as big as I could go without cutting the car. There is slight rubbing on steep, angled, inclines.
Old 02-08-2005, 10:57 AM
trapin's Avatar
Mark....I sold the springs locally back in December.
I am going to just wait and get the full weight of the vehicle on them with the engine, trans, back seat, interior and fuel tank assembly before I make any adjustments.
On a side note; MAN does my car look ratty in those pictures. I hate taking pictures of my car during trial assembly. Looks nasty.
Tony Rapin
Old 02-08-2005, 07:12 PM
Steve Chryssos's Avatar
Looks good Tony,
Judging by your wheel and tire combo, you will be way happy with the 3" springs. Every car is different, so you won't know til you know. Case in point, I installed a bigger fuel cell a coupla months back and now, if I fill the tank up the ass is too low. So the advertised spring drop is relative.
________________
Steve Chryssos
Ridetech.com
Old 02-09-2005, 01:09 PM
XcYZ's Avatar
XcYZ XcYZ is offline
I wouldn't sweat it, Tony. I have the DSE 3" drop leafs, and I think they're great, right where I want it to be.
My LS7 69 Camaro
Old 02-10-2005, 07:26 AM
Oh yeah..one more thing. You may find yourself fiddling around with tailpipes and shock length with the 3" springs--but it's still worthwhile. So save those parts for last--after the car is all together.
________________
Steve Chryssos
Ridetech.com
Old 02-10-2005, 08:53 AM
jannes_z-28's Avatar
Another important thing to remember that is easy to forget when you're under the car putting the springs in place.
-- Don't tighten the shackles until the car is fully loaded (engine and trans mounted) on the ground.
Jan
Jan Suhr
Stockholm, Sweden
'69 Camaro Z/28 LS1/T56
