Old 09-10-2012, 07:28 PM
BANKO's Avatar
BANKO BANKO is offline
Default How to approximate section width bulge / stretch without mounting tires?
Hey Guys, I'm trying to stuff 10.5" wheel running a 295/35/19 BFG KDW2 tire in the rear of my Chevelle. I'm concerned about section width bulge since I am tight to both sides of the wheel well.
For a 295/35 on a 10.5" wheel the width is 11.9"
For a 285/35 on a 10" wheel the width is 11.6"
Do you know of a way to approximate a 285/35 on a 10.5" wheel? I'm hoping to get closer to 11" section width.
Josh
Designing a '65 Chevelle with a StreetFighter theme, inspired by JP's II Much & Ron Schwarz's $5k Mustang
Old 09-10-2012, 09:05 PM
Mkelcy's Avatar
Mkelcy Mkelcy is offline
Unless you've got a typo above, any tire on a wider wheel is going to have a wider cross section. If a 285/35 on a 10" wheel is 11.6", a 285/35 on a 10.5" wheel is going to be about 11.8".
The rule of thumb (at least as pronounced on the Tirerack site) is a 0.2" change in cross section for each 0.5" change in wheel width.
