Old 09-23-2012, 04:43 AM
Default Is it possibale? Has it been done .. Pics?
On a Gen 1 camaro (67 in my case) running an aftermarket sub and wheel tubs... 18x10 aon all 4 corners with the same offset/backspace....
starting to think about wheels / sub/ axle and was thinking about this option... being able to balance F to Rear and rotate all 4 corners..
Old 09-23-2012, 05:23 PM
295 30 18 on all four corners possible?
Old 09-24-2012, 10:52 AM
Rybar's Avatar
Rybar Rybar is offline
I think CarlC has 275's all the way around on a stock front sub. You may need those speedtech high clearance arms and may need to notch the frame rail. But not sure you could run the same BS front to rear anyways.
1969 CAMARO RS
Lateral-G Feature Page
Project pics of my '69
Old 09-24-2012, 12:30 PM
Flash68's Avatar
Flash68 Flash68 is offline
I don't see why you could not do it. Several guys running 295 up front with aftermarket subs (more room on a 69) and as long as you got your rear end width dialed in properly you should be able to make it happen.
Like Ry said, it's been done with 275s and would give you wiggle room.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
