Old 09-24-2012, 08:13 AM
Phaeton's Avatar
Phaeton Phaeton is offline
Default Question for Recovery Room
Getting ready to start the interior and have a question for you.
What do they use for the chrome strip? Is is 3m self adhesive D strip or something else. How do they finish off the ends?
Thank you for your help.
1967 Chevillain
https://lateral-g.net/forums/showthread.php4?t=38121
Old 09-24-2012, 10:20 AM
ccracin's Avatar
ccracin ccracin is offline
Tracy probably has some other options, but here is one. It is solid material and can be finished on the ends however you prefer.
http://www.claytonmachine.com/interior-trim.html
Chad
Instagram - @cctek
68 Chevy Pickup Project
Old 09-24-2012, 02:19 PM
Phaeton's Avatar
That's more like it. How is it attached? Glue?
1967 Chevillain
Old 09-28-2012, 06:00 PM
HRD's Avatar
HRD HRD is offline
I think they generally drill some small holes in the back of the strip, not all the way through and use real small screws like #4 to attach.
Old 09-29-2012, 12:38 AM
RECOVERY ROOM's Avatar
Supporting Vendor
RecoveryRoomInteriors.com
Sorry for being late to the party.. Yes thats the stuff to use, Ill get Claytons trim sticks all the time. There a soft aluminum so you can shape them and sand the ends anyway you want. I have a jig set up to drill the backside with a very small bit 5/64 then run a very small screw into to hold on. I have even cut them in half to make it 1/8 wide for really detailed trim work. Sand smooth and polish
TRACY WEAVER
www.recoveryroominteriors.com
Old 09-29-2012, 11:06 AM
Phaeton's Avatar
Thank you for the help
1967 Chevillain
