Old 11-01-2012, 02:38 AM
69x22's Avatar
69x22 69x22 is offline
Default Best oil to run.
I recently swapped from Castrol 10w40 to Royal Purple 10w40 HPE. After about 1100 miles it looks dark and broke down. I see on the LS sight allot of the guys are running the Shell Rotello 5w50 with good results. What do you guys think about running this oil in a LS? I know it has more Zinc than most oils but what about the weight?
1952 Ford F1 817 HP 8-71 Supercharged 502
1957 Chevy 454LSX
1969 Camaro 830 RWHP ProCharged LS 416
https://lateral-g.net/forums/show...ighlight=yenko
https://lateral-g.net/forums/showthread.php4?t=34171
Old 11-01-2012, 04:11 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Looking at oil with the naked eye doesn't tell much of anything. If you really want to know, get it analyzed.
Unless there's a problem with the engine, the RP you're running is fine. Rotella would be a downgrade.
Read this: Puts all the zddp bs to rest.
ZDDP: http://speedtalk.com/forum/viewtopic.php?f=1&t=31791
Diesel oil: http://speedtalk.com/forum/viewtopic.php?f=1&t=32279
Old 11-01-2012, 04:30 PM
Syclone892's Avatar
Syclone892 Syclone892 is offline
If you really want to know what the oil like after use you should do an oil sample. If you are really concerned you can do a sample of a brand new bottle of oil then do a couple used samples so you get a baseline and that should help determine if you need to switch oil or if it is in fact still good to go.
We use fabco / cat oil sample kits as they only cost $12 and that includes the postage.
As far as oil goes we use at my work off road oil mainly marketed for farm tractor use. With 7000 miles on my duramax our oil rep said the #'s on the sample would have to triple before he would even start to worry so this oil change is scheduled for 10k miles and I will recheck then to see where we are at.
The oil we use is called Central Petroleum Company (CenPeCo), I have personally looked at the bearings on a 200k mile lumina 3.1l engine that looked like they were just installed they looked that great.
If you would like lots of info I can give you our oil reps # and he will talk your ear off he knows his product and has proof through oil samples that it works!
Good luck and send me an email if you want to talk more
David Van Hulst
'91 GMC Syclone #892
'92 GMC Typhoon #0076 Dads
'92 GMC Typhoon # Project Burnt Ty
Old 11-01-2012, 11:11 PM
69x22's Avatar
Thanks for the info guys.
1957 Chevy 454LSX
Old 11-02-2012, 06:48 AM
LS1-IROC's Avatar
LS1-IROC LS1-IROC is offline
I wouldn't put RP in any engine I care about.
Old 11-02-2012, 05:41 PM
69x22's Avatar
Thats the problem if you ask 20 people you will get 20 different answers. I had one guy tell be he wouldn't use RP on his door hinge. LOL
I think I am going to pull a sample and have it checked where I work at.
1957 Chevy 454LSX
Old 11-02-2012, 06:29 PM
badmatt's Avatar
badmatt badmatt is offline
amsoil.
Old 11-02-2012, 09:12 PM
Sieg's Avatar
Sieg Sieg is offline
When someone says they wouldn't use it, for the benefit of others, stating "why" would help.
Engineering analysis is the only sure way to separate marketing from chemistry.
Old 11-02-2012, 09:14 PM
Sieg's Avatar
Originally Posted by badmatt View Post
amsoil.
Redline
PS - I'm lucky at Liar's poker.
Old 11-02-2012, 09:26 PM
intocarss's Avatar
I run RedLine in everything
