Old 01-01-2013, 06:08 PM
Vortech404 Vortech404 is offline
Default 315 clearance?
Will a 315 on a 18x11 wheel fit on a 69 camaro without notching
the rear frame rail? anybody have pics?
Tried searching but you know how that goes.
John
Old 01-01-2013, 06:30 PM
Track Junky's Avatar
I've gotten up to a 325 in by custom mini-tubbing, not touching frame rail, and leaving the leaf springs in the stock location. Back spacing on a 10.5 wide wheel is 6.5 but 6.75 will work especially with a 315 which is what I run now. Clearancing at quarter panel lip required. Pic is with the 325.
Gaetano Cosentino
Old 01-01-2013, 06:49 PM
Track Junky,
Thanks for the reply. Also forgot to mention I will be running a SpeedTech T/A
setup. So are you saying I could just install some Dynacorn tubs and be all set?
Thanks for the pics. can't really tell how close the tire is to the frame rail though with that
leaf spring. How much clearance would you say you have?
Thanks again
John
Old 01-01-2013, 07:05 PM
Not sure what the dynacorn tub requires. I (my fabricator) cut the stock inner tub out and moved it over and added a 1 9/16" strip of sheetmetal in between. Thats about a 1/2" clearance to the leaf spring. I dont recommend doing this without adding a watts link if you are running low enough to be over the tire with quarter panel. Here are pics with the 315's. You can see how low I am in the rear and running hard in the corners causes the rear diff to shift side to side without a watts link in turn hitting the quarter panels.
Gaetano Cosentino
Old 01-01-2013, 07:06 PM
Vince@Meanstreets's Avatar
He has 3/4" to 1" in spots.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 01-01-2013, 07:07 PM
you should be good with the Speed tech T/A panhard bar.
Dealer for
NEVER FORGET -11
Old 01-01-2013, 07:11 PM
Pics with the 315's and Fays 2 watts link. Probably 7/8" clearance with 315's to leaf spring.
Gaetano Cosentino
Old 01-01-2013, 07:55 PM
v8s only's Avatar
v8s only v8s only is offline
my 69 camaro has dynacorn tubs speedteck torquearm no notching the frame rails and it has 335 30 18 on 12 inch rim with no rubbing and I do race the car but i did install the frame rails inboard about 1/4 inch on each side and rolled the quarter panel lip
Tony
68 Camaro pro touring sold
69 Camaro pro touring for sale
62 corvette pro touring sold at barrett jackson
Old 01-01-2013, 09:00 PM
really? no frame notching at all? so the frame rails are moved in?
Dealer for
NEVER FORGET -11
Old 01-01-2013, 09:52 PM
v8s only's Avatar
frame rails are only moved in about 1/4 inch at the rear the speedteck shock cross member still fits between the rails
Tony
