Old 01-05-2013, 03:45 PM
RussMurco's Avatar
RussMurco RussMurco is offline
Default 1970 Firebird sail panels...
Are there reproduction quarters with sail panels available for these cars? I couldn't find any in either the Classic Industries or Year One catalogs, not even the sail panels alone.
Russ "Murco" Murray
http://i1339.photobucket.com/albums/...psc7bc7b5c.jpg
"Liquidating excess cash through the automotive hobby!"
Old 01-05-2013, 04:36 PM
RussMurco's Avatar
Originally Posted by ratman67 View Post
you should be able to find that used oem, i would prefer buying that section oem as you know it will fit right in, its very high off the ground, so getting a nice rust free one should be easy. you only need the outer skin correct?
Yup, the floors and inner panels are perfect!
I think you're right, after looking through some posts about reproduction body panel problems a used OEM piece might be my best bet...
Russ "Murco" Murray
Old 01-05-2013, 06:19 PM
srh3trinity srh3trinity is offline
I had a vinyl roof car and mine had a fair amount of rust in the sails. I had my sheetmetal guys fab some up, but I wish I would have sourced a donor car to cut the piece out of. I will probably have to do that anyway as it will be hard to body work the one they fabbed up. It didn't come out as good as I had hoped.
Stephen
Old 01-05-2013, 10:06 PM
Musclerodz's Avatar
currently only 80% skins available for 70-73 firebirds which I am suprised to still see. tail panels were just released last year and if you can find an NOS quarter, expect to pay nearly $2k for it.
Mike Redpath
Musclerodz & Customz
facebook page
Old 01-07-2013, 01:06 PM
RussMurco's Avatar
Yikes!
I'll look for a donor piece, I'm starting to suspect this was originally a vinyl-top car as the roof is good and I only found mud on the lower part of the sail, where the pins for the trim would be. I'll be getting it blasted soon, all the secrets will be revealed!
Russ "Murco" Murray
Old 01-07-2013, 03:32 PM
tazzz2_ca's Avatar
tazzz2_ca tazzz2_ca is offline
In a worse case deal you could stitch a 74 replacement panel sail section into the existing panel.... Not a great option,,, but at least it's an option....
-73TA WarPath (Summer 2016)
-72RS Il Vagabondo
-70 Blue Formula "Project Cochise"
-70 Z shell
-70 Formula shell
-70 Formula roller
-68 Eldorado
-67 Coupe De Ville convertible
Old 01-08-2013, 04:35 PM
RussMurco's Avatar
I haven't seem a replacement for a '74 anywhere, can you recall where you found one? And is there any difference other than the last 6" of the rear?
Russ "Murco" Murray
Old 01-08-2013, 04:38 PM
RussMurco's Avatar
the previous owner did a nice job of cutting the package tray for some jensen 6x9s lol
Yup, that's some true craftsmanship there... At least there isn't a pop-out sunroof and those T/A flares that went behind the wheel-wells!
Russ "Murco" Murray
Old 01-09-2013, 07:04 AM
redfire69's Avatar
redfire69 redfire69 is offline
Check out Frank's Pontiac parts, he's got a RH quarter and usually gets these in occasionally.
http://www.frankspontiacparts.com/us...rdtransam2.htm
Ron
69 Camaro Redfire
Old 01-09-2013, 09:40 AM
RussMurco's Avatar
You know, I had forgotten all about his joint and I used to be stationed in the litter-box up the road! I'll be driving through there in 2 weeks heading to the GNRS, I'll give him a buzz!!! Thanks!!!
Russ "Murco" Murray
