Old 01-24-2013, 06:55 PM
Atomic69 Atomic69 is offline
Default Auto to t56 Swap cost for 1969 Camaro
Hello all,
I'm new to the site but have been lurking for some time now. I live in the bay area and would like to know of some of the better shops capable of swapping my th350 out for a T56 in my camaro. For those familiar with this, can you please chime in on final cost with/without supplied transmission and associated hardware.
Thanks again, great site by the way
Old 01-25-2013, 10:43 AM
chr2002ca's Avatar
I've actually been doing this sort of swap and here's my cost breakdown on parts only. I buy from the major parts warehouses like Summit, Jegs, and Streetside so you might be able to get a better price elsewhere but you may have delays. Also, you could probably save a decent chunk of change if you bought a complete kit from a single dealer instead of piecing things together like I have.
Tremec LS T-56 Magnum (includes $112 freight+handling charge), $3006
Shifter stick and ball for Tremec shifter, Hurst, Approximately, $110
Quicktime Bellhousing, RM-6023, $451
Block to bellhousing Dowels, 37932, $13
Offset Dowels(if necessary), $28
Centerforce DYAD Dual-disc clutch/flywheel, $1480
Hydraulic Throwout Bearing, lines, and bleeder kit, approx $320
Pilot Bearing(if needed), $12
Yoke - 31 spline, 1350 series, Moser TY800, $130
Electronic Speedo sending unit and proper gear, approx $50-$75
Transmission mount(TH400/T56), 3-1108G, $28
Crossmember - ATS/Speedtech T56 (price includes $37 shipping), ATS 080001, $407
Clutch Master Cylinder and mounting hardware, Keisler, $315
Pedal Assembly and hardware, Classic Industries, $100
Modo Pedal Covers for manual setup, Modo Innovations, $120
Driveshaft shortened, approx $100
Fluid for transmission, $20
DOT 4 fluid for hydraulics, $5
Chris Robinson
Old 01-25-2013, 01:17 PM
67zo6Camaro's Avatar
67zo6Camaro 67zo6Camaro is offline
That's good bookkeeping Chris. Good info here.
Old 01-25-2013, 10:42 PM
Thanks, this was a VERY detailed answer lol. I do appreciate it. Looks like I'll be pulling out a loan or two to make this happen. Any reputable shops you all would suggest to take on this task?
Thanks again guys
Old 01-25-2013, 10:52 PM
garickman garickman is offline
Thanks again guys
You might want to call Vince at Mean Streets Performance. He can take car of everything you need. He just opened a nice new location in San Carlos right off the freeway. He does a lot of pro touring builds. He is an honest guy with great skills. You can search this forum and Pro-Touring.com and see how happy people are with his work as well as his prices.
Service and Retail store
827 Cherry lane
San Carlos CA 94070
(415) 271-4839 [email protected]
He posts on this forum as Vince@MSperfab
Greg
