Old 03-04-2013, 06:58 AM
Beach Cruiser's Avatar
Beach Cruiser Beach Cruiser is offline
Default Complete SBC 377
I pulled this motor from my 67 Camaro in favor of an LS1 swap. I have video of the motor running when it was pulled. Been in my garage taking up space since. Motor runs well, but has been sitting for a while. Here's the specs on the motor. Everything was the best of the best when the motor was built.
4bolt main 400 block, .020 over 10.5:1 CR
Forged Steel Crank (350) I think it's knife edged
Wiseco 377 pistons, 5.7 pink rods
Crane Fireball Cam
Chevy 441 heads, opened up for 2.02/1.90 valves, Stainless swirl polished tulip valves. Heads are ported and port matched.
Edelbrock tourqer (original style) intake with 650 holly Mech carb.
HEI small cap distibuter.
Brand new clutch still bolted on
This motor will scream! not the torquiest motors at the bottom, but will pull past 7k if you dare. Complete motor from Carb to the header collectors. Moroso chrome valve covers, chrome timing chain cover and chrome oil pan. You even get the roll around engine stand it's sitting on!
Located in Virginia Beach, VA I'm asking $2500 for everything.
https://www.youtube.com/watch?v=MVFgb1UG4L0
No Shop, No Money, No Time.... No problem!
Old 03-05-2013, 06:16 AM
Wow, 98 hits and no comments? Is my price way out of the ballpark? Does no one want a small block anymore in the age of the LS?
Old 03-05-2013, 10:31 AM
Roberts68 Roberts68 is offline
I confess I looked at it.
Any dyno slips or invoices on it?
If it was closer it would have peaked my interest more.
Old 03-05-2013, 10:38 AM
I wish I had some numbers on it, but I built it so long ago. It's been mostly sitting in the car since I graduated college and raised two boys! The video of it running is just last year when I fired it back up again to prove it's a running motor. It should be over 400hp to the wheels but I have no proof. It should be gone through and freshened up, but nothing is wrong with it and I suspect it would be very difficult to find most of the parts that are in it today. Some of them where difficult to find 25years ago.
Old 03-05-2013, 10:44 AM
Flash68's Avatar
Flash68 Flash68 is offline
I looked at it because I just blew mine up last year. But a 377 is a fun revving motor.
If I were a buyer I'd want cam specs.
2004 NASA AIX Mustang LS2 #14
1964 Lincoln Continental
2014 4 tap Keezer
Old 03-05-2013, 10:50 AM
Cam Specs I do have! found the cam card in the console when I took it apart! I'll post that info up tonight when I get home. If yours blew up you need spare parts right? LOL You are the only other person I've seen with this motor combo.
Old 03-05-2013, 11:39 AM
I didn't notice the Cam listed as a Crane Fireball when I skimmed it. I'm going to laugh if it is the same cam I have now in the 327. Only because of the coincidence, mine is likely the same era... predates my daughter who turns 21 next month.
No disrespect meant. Mine likes to rev too, likely a little much cam for a 327
Old 03-05-2013, 01:57 PM
carbuff's Avatar
carbuff carbuff is offline
I read it also, because I too used to own one.
http://carbuff.homeip.net/engine.html
I loved that engine! It was ridiculous how quickly it would spin up...
GLWS!
Old 03-05-2013, 05:19 PM
Flash68's Avatar
It was fun while it lasted but I've added a bunch more cubes to add torque to the horsepower.
2014 4 tap Keezer
Old 03-05-2013, 06:27 PM
Ok, so I pulled the Cam Card out of the console (which was covered in dust on the top shelf of the garage!) Part No 114201, 455/296 int 455/296 ext. Crane Fireball 296A is the grind number. No where does it tell me the LSA, but it's pretty lopey.
