Old 04-06-2006, 08:10 AM
fletcherscustoms fletcherscustoms is offline
Default Thought someone might find it usefel, others dishearting!! Parts list of my project!
Here is a copy of my spreadsheet I have been keeping on the "Shop Beater" project. This was basically built from scratch, all I had original was the shell and seat frames!! Every screw, nut, bolt, trim piece, etc is all brand new. This by far not the way to build a car. The nickle and dime parts really eat you up. This also does not include sheetmetal
Company Purchased From: Manufacturer Part # Description Price
Car purchase Chevy 69 x-11 junker $5,500.00
Auto Paint Center PPG BCA/01 Base Coat $288.40
Auto Paint Center PPG D872/01 Reducer $56.45
Jeg's Wilwood 950-260-8556p Master Cylinder $241.99
Jeg's Wilwood 950-260-8419 Proportioning Valve $39.99
Jeg's Autolite 410-ar3924 Spark plug $49.90
Jeg's Jeg's 555-10250 Battery Holder $109.99
Summit AER-FBM2405 10AN female bung $21.95
Summit March MCH-20720 Alternator Bracket $163.88
Summit MRG-W10 10AN Male bung $6.99
Summit MSD MSD-6420 MSD 6AL $205.88
Summit MSD MSD-8474 MSD HEI $319.88
Summit Thorley DTE-376Y1C Tri-Y header $528.69
Summit Flowmaster FLO-17201 Exhaust System $599.95
Summit March MCH-6031 Crank Pulley $68.88
Summit Pro Parts PRO-141-801 Valve Covers $269.95
Summit Powermaster PWM-67294 Alternator $199.88
Summit Summit SUM-420101 Alt. Bracket $69.95
Summit Summit SUM-G2301 Valve Cover Gasket $10.95
DSE DSE 40401 Deep Tubs $399.00
DSE DSE 40601 Shock x-member $85.00
DSE DSE 40501 Upper Shock Mounts $18.00
DSE DSE 40901 Offset Shackles $275.00
DSE DSE 40102 3" Drop Leafs $375.00
DSE DSE 40201 Leaf pads $55.00
DSE DSE 40301r Lower Shock Plate $52.00
DSE DSE 40701 u-bolts $29.95
DSE DSE 41202 tub install video $24.95
DSE DSE 10901 Firewall fill plate $65.00
DSE DSE 10101 subframe connectors $175.00
DSE DSE 10301 body mounts $110.00
DSE DSE 10801 stainless body bolts $60.00
DSE DSE 30101 Upper Control Arms $650.00
DSE DSE 30201 Lower control Arm bushings $149.95
DSE KONI 31002 Front Koni Shocks $198.00
DSE DSE 31103 2" Drop Coils $87.50
DSE DSE 31401 Front Sway bar $185.00
DSE DSE 91001 Power Steering Pump $150.00
DSE DSE 90801 Steering Pulley $55.00
DSE DSE 91201 Hose Kit $109.00
DSE DSE 90204 600 Steering Gear $485.00
DSE DSE 91701 Pressure Line $49.95
DSE DSE 80102 Narrowed Fuel Tank $745.00
DSE KONI 41301 Koni Rear Shocks $210.00
DSE DSE 90205 Rag joint $60.00
DSE DSE 92101 Steer Pump Mount $58.00
DSE DSE 80201 Fuel Sending unit $42.00
Precision Brakes 14-FO-0084-X Rear Brakes $1,699.00
Precision Brakes Front Brakes $1,299.00
Precision Brakes Front to Rear line set $208.00
Classic Chevy 5 Speed TKO TKO600 Elite 5 Speed Tranny $4,473.98
American Auto Wire AAW Wire Harness $439.00
Moser Engineering MOSER Ford 9" Rearend $2,315.29
Hydratech HYDRATECH Hydroboost brake booster $713.00
Jeg's JEGS 555-110562 10AN Bulkhead $19.99
Jeg's JEGS 555-80625 AN ADJ. Wrench $34.99
Jeg's JEGS 555-110023 10an swivel $19.99
Jeg's 023-FCM2038 08AN /1/2 NPT $15.99
Jeg's BILLET SPEC 135-30435 Rail Wheel $209.99
Jeg's BILLET SPEC 135-29008 Black half wrap $39.99
Jeg's BILLET SPEC 135-32125 Smooth LG horn $44.99
Jeg's BILLET SPEC 135-90320 15" swivel t-stat neck $69.99
Jeg's MEZIER 680-WP1175U water pump fitting $15.99
Jeg's IDIDIT 535-1520790020 steering column $579.99
Jeg's JEGS 555-41000 engine t-mometer $29.99
Intro Wheels Intro Vrod 18x8 Front wheels $975.00
Intro Wheels Intro Vrod 18x12 Back Wheels $1,525.00
Barrons Tire Michelin 335/30/18 back tires $900.00
Barrrons tire Michelin 245/40/18 front tires $900.00
Rick's First Gen RSK-4A STD deluxe interior kit $969.00
Rick's First Gen SV-10C sunvisors $59.95
Rick's First Gen HW-84 pillar post molding $2.95
Rick's First Gen HL-34 headliner bow clips $14.95
Rick's First Gen HL-32 headliner sail panel clips $4.50
Rick's First Gen HT-12 headliner trim molding $169.95
Rick's First Gen DJ-90 door jamb edge welt $79.95
Rick's First Gen IN-23R astro vent grille $39.90
Rick's First Gen HW-30 vent screws $0.50
Rick's First Gen HW-94 package tray corner screws $1.30
Rick's First Gen SB-69 3 point selt belt $279.95
Rick's First Gen IN-37 firewall pad $39.95
Rick's First Gen IN-97 carpet firewall gaurd $34.95
Rick's First Gen IN-197 firewall guard screws $4.95
Rick's First Gen CMC-4 console kit $359.00
Rick's First Gen CP-114 floor and nut bolts $5.95
Rick's First Gen CP-46 console floor bracket $14.95
Rick's First Gen CP-115 rivet nut tool $3.95
Rick's First Gen B-569 69 sport comp cluster $639.95
Rick's First Gen SF-60P std seat foam set $169.95
Rick's First Gen IN-136 seat hinge cover fastener $3.59
Rick's First Gen IN-62 seat back panels $79.95
Rick's First Gen WW-36 weatherstrip kit $189.00
Rick's First Gen 8008 weatherstrip adhesive $8.95
Rick's First Gen RGK-5 glass kit $699.00
Rick's First Gen WM-26 windsheild mold clip $9.95
Rick's First Gen WM-28 rear window mold clip $12.95
Rick's First Gen WM-40 molding clip pin stud $3.00
Rick's First Gen WM-7 windshield lower molding clip $14.95
Rick's First Gen WM-8 windshield outer clips $7.95
Rick's First Gen HW-75 window blowout set $12.95
Rick's First Gen WM-17 mold clip tool $16.95
Rick's First Gen WM-29 glass seal $19.90
Rick's First Gen LB-10 quarter glass chrome $79.95
Rick's First Gen WR-86 door glass mount kit $199.95
Rick's First Gen WR-51 window track plate $7.50
Rick's First Gen DH-15 door lock striker $23.90
Rick's First Gen ID-3 lock set $29.95
Rick's First Gen ID-5 trunk lock set $31.95
Rick's First Gen TP-25 trunk lock retainer $16.95
Rick's First Gen WB-50 wiper tranny $89.00
Rick's First Gen WB-69 delay wiper kit $233.00
Rick's First Gen HD-26 upper hood latch $27.95
Rick's First Gen HD-55 hood spring $25.90
Rick's First Gen PP-13 drain plugs $19.50
Jeg's Autometer 105-3327 Sport Comp Elec Oil pressure $49.99
Jeg's Barry grant 132-140019 pump/filter adaptor $12.99
Jeg's Jeg's 555-110150 90 degree, 1/2" to 10AN $14.99
Jeg's Jeg's 555-110110 1/2 npt x 10AN straight $5.99
Jeg's Jeg's 555-110108 3/8" npt x 10AN straight $11.98
Jeg's Jeg's 555-100417 3/8 npt nipple $5.99
Jeg's Jeg's 555-110023 10AN 90 degree swivel $79.96
Jeg's Jeg's 555-110002 8AN Straight end $20.97
Jeg's Jeg's 555-110003 10an straight end $8.99
Jeg's Jeg's 555-80575 wire crimpers $13.99
Jeg's Jeg's 555-110166 radius pump fitting 10AN x 8AN $12.99
Jeg's Jeg's 555-10365 rubber grommets $9.99
Jeg's Jeg's 555-15221 carb cap $5.99
Jeg's Holley 510-34-39 fuel log $189.99
Jeg's 361-1847004 assembly lube $6.99
Summit Billet specialties BSP-31120 wheel adaptor $44.50
Summit Ididit IDT-300053434 rag joint $99.95
Summit JDM-PIVSE-P4 Ground Strap Kit $43.50
Summit K&N KNN-66-3210 Air filter $137.69
Summit MRG-2372 7/16 wheel spacer $12.88
Summit SWC-FWB0 1/0 Grommet $31.80
Summit SWS-FWB4 4/0 grommet $7.95
Summit SWS-FWB8 8/0 Grommet $7.95
Summit Taylor TAY-45909 36" Coil wire, 10.4mm $14.69
Summit Taylor TAY-98030 spark Plug Wires $111.99
Summit TRD-4082 1/4 wheel spacer $13.99
Moser Moser 8050 7/16-20 x 2 7/8" studs $22.50
Jeg's Jeg's 555-30643 3" turndowns $34.99
Jeg's Baer 136-200010 1/2"spacer $67.98
Jeg's Painless 764-50106 pump relay $29.99
Jeg's Be Cool 134-75118 fan control $159.99
Jeg's 891-tc002s16 radiator cap $19.99
Jeg's 710-73163 plug wire seperators $8.99
Jeg's 778-141-636 plug wire seperators $9.99
Rick's First Gen DSE HH-20 7" halogen bulbs $199.00
Rick's First Gen EM-9 ss grille emblem $44.20
Rick's First Gen EM-20R header emblem $14.95
Rick's First Gen EM-82 SS tail panel emblem $24.95
Rick's First Gen LP-3 rear plate bracket $24.95
Rick's First Gen IN-144 dash pad clips $8.95
Rick's First Gen HH-7 window crank $15.90
Rick's First Gen HH-8 lh light bucket $26.00
Rick's First Gen PK-37 rh light bucket $26.00
Rick's First Gen MB-26 side marker $54.95
Rick's First Gen BU-65 outer front bumper bracket $16.95
Rick's First Gen BU-20 fr bumper mounts $12.95
Rick's First Gen HW-40 glove box screw $3.50
Rick's First Gen IN-152 glove box latch $7.75
Rick's First Gen IN-10 glove box liner $14.95
Rick's First Gen WS-41 glove box door bumper $1.95
Rick's First Gen WS-78 glove box door stop $1.40
Rick's First Gen IN-32K grab bar kit $109.95
Rick's First Gen 395662 upper rad hose $15.95
Rick's First Gen 3942561 lower rad hose $15.95
Rick's First Gen IN-157 door lock knobs $4.95
Rick's First Gen IN-158 lock knob ferrules $3.95
Rick's First Gen HL-32 sail panel clips $4.50
Rick's First Gen HW-150 int bolt kit $115.00
Rick's First Gen HR-13 column cover $22.95
Rick's First Gen HW-90 cover hardware $2.95
Rick's First Gen SW-18 stoplight switch $9.95
Rick's First Gen SW-37 switch hardware $2.00
Rick's First Gen HD-18P hood stop screws $7.95
Rick's First Gen FWG-1 firewall gutter $5.95
Rick's First Gen WS-18 firewall seal set $16.95
Rick's First Gen WS-19 body bumper set $12.95
Rick's First Gen PP-129 pillar roof drip support $84.95
TOTAL 37271.35
Old 04-06-2006, 08:28 AM
BC69's Avatar
BC69 BC69 is offline
Thats one hell of a list. But that is a good idea to keep track of all the costs. Even though the total may be a little shocking, at least you know it, and it can help for next time or for others to find ways to cut costs here and there.
I tried keeping an excel model of my costs when I first got my car, but it didnt turn out so organized.
Thanks for sharing.
Tim
In memory of those gone before us
In gratitude for those who care.
Old 04-06-2006, 08:30 AM
orange88 orange88 is offline
dont ya love the small stuff
Old 04-06-2006, 08:31 AM
Thanks for sharing.
Tim
yeah I have every receipt, shipping document, etc. I know everything about this car, I assembled, I bought the parts, and I did it all!! I was really hoping to keep the build under the $25K, but I threw in a 5 speed, then came 9", then big brakes, you know it just rolled down hill from there. Oh well , looks like the price tag will be $50K if someone wants it now!!
Old 04-06-2006, 12:28 PM
Payton King's Avatar
Default been there
as a matter of fact I am still there. My list is long and expensive as well, you still have a ways to go to catch me as I really did it the long and expensive way...replace every panel with GM NOS stuff, etc
I did not see a motor in you list or did I just get lost in the numbers. LOL
Old 04-06-2006, 12:32 PM
Sales@Dutchboys's Avatar
I just made an order to jegs the other day..........950$$ and it all was in 1 box........
dutchboyshotrods.com
269-823-2967
Old 04-06-2006, 12:34 PM
Lateral-g Moderator
Like you said alot of things are missing from the list. Makes you want to flash the the list like this when the guy at a car show walks up and sais " I can build this car for 30K".
Old 04-06-2006, 12:38 PM
yeah this is all the out of pocket cost so far!! The motor has been sitting on a stand in my shop for a little over a year jsut waiting to go in something!! If I add in the motor and other stuff I used I already had we'd be over $45K already
Old 04-06-2006, 01:00 PM
Default yep
I thought you were holding back. Your are in deep, just don't look back.
Stuart I was that guy. When you bought the red 68 I was really considering selling my 69 project to buy it, I was thinking, hey for the sales price mine would be way better. Nope I was wrong. I will be in double by the time it is finished...and I could have been driving for the last 3 years instead of building this thing.
Old 04-06-2006, 01:05 PM
Lateral-g Moderator
Payton, I know its amazing how many dollars these cars TRULY cost. It takes building one to TRULY find out , huh. LOL.
What a disease.....
