Old 04-13-2013, 01:29 PM
Default Building my big ten bolt or why not
I'm fairly certain that the 10 bolt in my car will need to be taken apart and redone. Last time I drove the car it was making bad noises. My thoughts have always been to simply keep the rear because it's strong, has plenty of aftermarket support, robs less power, and I won't ever "need" a 9in or 12 bolt power wise. My question is who can build my ten bolt up near me? Near being relative as I'm more than willing to go into OKC, Denver, ABQ, Dallas etc if I have to. Really, I think all I'll need to do is put new axle tubes on the housing, have them aligned, and fully welded. I already have 3.42 gears. Maybe I'll spring for a new posi unit or look to upgrade the stocker if possible.
The other question is why shouldn't I build it or why should I go with a 12bolt or 9in? Car is a street car and will remain that way for a long time to come. I'm looking at a TA suspension most like from Speed Tech or JRS and I'm fairly certain they can both be made to fit the big 10 bolt. Is there anything else I should consider when making this decision?
Thanks!
Old 04-13-2013, 04:50 PM
gerno's Avatar
gerno gerno is offline
I'm about to do a 9" swap in my 2nd gen as well. Power wise I'm not afraid of the ring gears holding up. My fear comes from the C-clips and the axle potentially falling out. I have had to pick up a friend who lost an axle driving down the highway without anything close to crazy power. I could only imagine what may happen if it's on a road course or autocross.
Old 04-14-2013, 11:50 AM
David Pozzi's Avatar
I'd install some aftermarket axles, The ten factory axles look good. I've had a couple of issues with Superior axles.
http://www.PozziRacing.com
Old 04-14-2013, 12:10 PM
Well, I put Strange axles in it while I was getting everything else in the car a few years ago. I'm going to be upset if they are damaged since they have only a few miles on them. I can't remember if the axles were anything special though. Is there a certain material or treatment I should look at when considering new axles?
Just how common is the c-clip falling out or breaking? Is it over hyped? There are so many axles with that design out there and I personally don't know anyone that has had issues.
Thanks guys.
Old 04-14-2013, 12:55 PM
Ketzer's Avatar
Ketzer Ketzer is offline
They make a kit to eliminate the C-clips. I think it's pretty common to do to any of the GM rearends if you have hp at all. How big a deal? Lots of stories both ways, guy raced for years and never broke one, guy was on his way to church in a low mileage stocker and shebango! I do know this, the carnage is usually ugly.
My car needs a rearend too but unless I was doing some kind of numbers matching thing (I'm not), I would not invest all the upgrades into a 10bolt. It sounds like you've already spent good money on yours so it makes since to finish it out.
Jeff-
Old 06-06-2013, 06:21 PM
Buick Grand National Guy Buick Grand National Guy is offline
The Buick Grand Nationals have 8.5" 10 bolt rear ends and they can take the power! Those V6's at 30 lb boost put our a TON of torque and the rears survive! You could convert it to a full floater if concerned that c-clip will break. I would not spend the $'s until I break something!
Conrad
Original owner of 1974 Z28. Ordered car with 4 speed, LT, Air Conditioning. Numbers matching car. Now equipped with Edelbrock Pro Flow fuel injection, 96 Zette Wheels, B-Car front disk, WS6 rear disk.
Also original owner of much-modified 1984 Grand National. Ridetech front & Detroit Speed rear control arms/sway bars Ridetech 3-way coil overs. Champion aluminum heads & intake. Comp roller hydraulic cam. CF hood, fiberglass bumpers. Baer 6P (2-piece rotors) 14" front & 13" rear brakes.
Old 06-07-2013, 04:54 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Before taking it apart, try to diagnose the noise first. It might just be an axle bearing.
Old 06-07-2013, 08:14 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
Until I break something I'm using a 12 bolt with C-Clips. I have C6 Z06 rear disc brakes though so a broken C-Clip isn't the end of the world as the brakes will PROBABLY hold the axle in until I can get stopped. Stuff might happen but my quarter panel should probably be OK I'm thinking. So, if you're running rear discs it's something to add to the equation.
Erik
69 Camaro
Old 06-07-2013, 08:49 AM
Ron Sutton's Avatar
The issue is not about the c-clip falling out or breaking. The issue is ... if the axle breaks ... the results are disastrous. The axle, tire & wheel combo come out of the car ... under load & at speed!
A c-clip eliminator converts your axle bearing to a press on bearing of better quality ... AND ... utilizes a bearing housing end that bolts onto the housing end/backing plate end. Not only is it stronger ... but if for any reason you break an axle ... the axle stays in the rear end.
Not so with factory c-clips ... if it breaks ... the axle, wheel & tire come OUT !
A full set up costs $130-180 ... so it is a VERY SMALL price to pay for a LOT of safety for you & the people around you ... and protection for your car.
Go to page 16 of Strange's catalog:
http://www.strangeengineering.net/catalog/index.html
Old 06-07-2013, 08:51 AM
Ron Sutton's Avatar
Erik,
If you don't mind sharing about your car ... how much HP? How do you drive the car? How much does it weigh? How big are the tires?
