Old 04-30-2013, 09:34 PM
HMA's Avatar
HMA HMA is offline
Default Anvil inner fenders?
I am looking to swap my stock sub up with the DSE hydrafrom sub and was considering swapping to the Anvil inners at the same time. Just wanted to see if they solve the clearance issue of rubbing on the outside edge of the inners. I know that they are supposed to be wider and taller than stock, is the clearance enough though? I am going to run a 275/35/18 in the front with 6.125" BS on a 9" rim. My current setup running a 245/40/18 with 5" BS on a 8" rim and barely rubs the inner fender on the outside edge as it curves up. If Anvil is not the way to go looking for recommendations. Is it worth modifying the original steel inners instead? Thanks for the help.
-Evan
67 Camaro RS
Old 04-30-2013, 09:51 PM
Ron in SoCal's Avatar
-Evan
Hey Evan - the Anvil inners pretty much line up directly with the factory fender lip. I mean you might gain 1/4" at most due to the shape, so unless I'm reaading your question wrong they aren't going to modify the outer clearance much. But...what they will buy you is inner and upper (as in lower stance) wheel clearance under compression. Also if you nail the BS you shouldn't have much of an issue on the outside. I'm sure the guys running DSE subs will chime in and clarify for you.
Great choice in parts BTW :thumbsup
Ron in SoCal
69 Camaro in progress
Old 04-30-2013, 10:14 PM
HMA's Avatar
HMA HMA is offline
Hey Ron thanks for the input, waiting for some more photos of your car! What I am referring specifically to is with the stock inners they curve up very gradually form the outside where they bolt to the fender, I am looking for more clearance from the inner fender "gradual" curve. That is where the clearance is needed about 2" in from the outside fender itself. Thanks again
67 Camaro RS
Old 04-30-2013, 10:58 PM
I hear you. That's where my 1/4" comes from above. Factory inners go up and in along the lip, Anvil's go down directly to the lip. Hope that helps!
Ron in SoCal
Old 05-01-2013, 12:15 AM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
Hey Evan, if you want to get the most amount of clearance out of your fenders, you'll want to roll the inside of the fender lip straight up. In my case I rolled the inside of the fender lip and just cut off the section of the inner fender between 9 o'clock and 3 o'clock. Does that make sense? You might have to see it to understand how I did it.
Old 05-01-2013, 10:20 PM
HMA's Avatar
HMA HMA is offline
Matt and Ron thanks for the input, makes sense I was looking at yours last weekend Matt and I think that is the route that I am going to take. I will cut the edge between the 3 and 9 to increase the clearance. I will just have to make sure that no wires or hoses are in the vicinity for the tire clearance. Thanks again for the input.
-Evan
67 Camaro RS
