Old 05-14-2013, 01:32 PM
19sixtynine's Avatar
19sixtynine 19sixtynine is offline
Default Bleeding brakes with a motorcycle bleeder?
A friend gave me her MightyVac bleeder to use on my car, 4 wheel corvette disc from KORE3, and I noticed it's a motorcycle bleeder. The Motorcycle version does not have a pressure gauge. How important is the pressure gauge when bleeding car brakes? Should I not use this bleeder? What bad can happen by using a bleeder without a pressure gauge?
This is the bleeder she is letting me borrow, for reference
Old 05-14-2013, 03:11 PM
MarkM66's Avatar
MarkM66 MarkM66 is offline
That gauge is for measuring low pressure, like testing a vacuum advance on a distributor.
Braking pressure will be higher then that tool could ever produce. You don't need the gauge to do brakes.
Old 05-14-2013, 04:17 PM
Cool, thanks MarkM66
