Old 06-10-2013, 07:59 AM
Rick D's Avatar
Rick D Rick D is offline
Default 2nd Gen rear wheel Backspacing
I know not all 2nd gens are the same but what is a good starting place for rear wheel Backspacing on a non mini tubed 2nd gen? And for that matter what about the front? It will have a OE sub frame with tubular control arms. It's a 73 if that makes a difference.
I found a nice deal on a pair of 18x10 wheels but not sure if they will work at either end?
Rick
Old 06-10-2013, 08:19 AM
coolwelder62's Avatar
Check with Marty/SyborgTT,I believe he has a stock 10 bolt in his 2nd gen.
Old 06-10-2013, 08:39 AM
syborg tt's Avatar
Hi Rick,
Is your car Mini-Tubbed or Stock Wheel Wells
My wheels are
5.75 Front - 18 x 8 (255 35 18 )
6.75 Rear - 18 x 10 (295 35 18 )
ps - Also have a set of drop spindles & blocks if you want them
marty-mj
Old 06-10-2013, 10:33 AM
markss28 markss28 is offline
Not to make things confusing but I have 18x8 and 18x10s with 4.5 BS and 5.5 BS. fits pretty good. No rubbing.
Never Stay Stock
Old 06-10-2013, 10:39 AM
I just ordered 19s so i may be selling my wheels if interested.
Never Stay Stock
Old 06-10-2013, 11:44 AM
syborg tt's Avatar
On a side note my Wheels and tires are 4-sale ( Yes I am blaming Kenny for this extra expense )
marty-mj
Old 06-15-2013, 12:34 AM
Vince@Meanstreets's Avatar
come on Rick, mini tub that 2 gen man....they are so easy to do.
damn Marty, how did you get 6.75 back there??? I can see 6" bs
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
Old 10-22-2013, 10:33 AM
Doug1's Avatar
Doug1 Doug1 is offline
I'm wanting to run 19x10s up front and 19x12s in the rear. Car has DSE tubs and pro-touring F-body upper and lower tubular control arms. Anyone have a similar setup? Stock rear end width.
Old 10-22-2013, 11:47 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
I talked with Jason @ Rushforth a bunch regarding the GenII fitment. There was only one control arm setup that allowed 10's on a stock sub. I cant recall what it was but it wasn't DSE. Wheel wells had to be modified as well. I went with 255's on 8'' rims on the front.
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 10-22-2013, 12:18 PM
syborg tt's Avatar
My guess would be Speed Tech's new Set up.
If you were running a 19" up front you might be able to put a 10" wide rim. However you would have some turning radius issue's
Give Keith at Custom Works Products ( www.customworksproducts.com ) a call he regularly beats the snot out of his 2nd gen and he is a speed tech dealer.
marty-mj
