Old 02-15-2005, 03:16 PM
Y-TRY Y-TRY is offline
Default A little of the Y-TRY build-up...(long)
I compiled some of the Updates I posted on local sites as I was building the car. Here's some of what went into it:
Well, one of the most complicated steps of installing the turbos was designing and fabricating the wastegate boxes.
To start, I used long thin bolts and a series of nuts to attach the turbos while being able to slide them up and down the length of the bolts to mock up the right distance and angles needed. The object was to determine what dimensions would work equally well for both sides while locating the turbos symmetrically in the engine bay as much as possible. This step was the most involved. But once done right, the same angles could be used to build both boxes. This is more complicated than it seems as the final angles are kinda complicated. I was working on 3 axis and the two flanges do not sit level with one another.
After a long time of measuring, scratching my head, and re-measuring- I presented the challenge to my cousin, Sean, to make the design a reality. He tacked together a mockup as a base version which I used to measure and re-measure again. After some minor changes, I settled on the final design and angles and it was ready to begin the real fabricating. We went up to his work, LG Motorsports, and got to work.
Starting with a 3" round tube, cut to length, he cut the precise angles into the ends. Since I already had the flanges from PT&E we needed to match the round tube to the rectangular openings in the flanges and turbos. To do this, he used a body hammer and angle iron to shape the round tube perfectly to fit. In the mean time, I was cleaning and tapping the flanges, foreseeing that the design left little space for nut/bolt combinations.
What we had now were two center sections with flanges, which were exactly the same. Since the turbos don't have a right and left side, simply flipping one box over for the other side mounts the turbos equally, and precisely opposite.
After assigning the boxes to their respective sides, Sean took a hole saw and cut out openings for the actual wastegate tubes and flanges. They're basically at 45 degree angles from the the headers and follow the lines of the inner fenders and tuck under the hood, while making sure to aim the outlet side towards the rear (note: the HKS wastegate flanges are NOT square and need to be installed appropriately).
I bolted up the turbos and boxes and everything fits perfectly. All the measuring and planning fell into place as the turbos are situated symmetrically in their place.
I then took it all apart again and dropped them off with my brother-in-law, Brandon, to grind all the seams and welds smooth in preparation for ceramic coating (being unemployed right now, he has time to do a good job on such a silly detail).
Old 02-15-2005, 03:17 PM
Default More...
So here they are prior to coating. They are arranged how they sit in the car and the top box in this pic is the passenger side. If you compare it to the previous pic you can kinda superimpose the box between the header and turbo and see where the angles fit in.
Old 02-15-2005, 03:18 PM
I then got my headers, boxes and a wastegate coated and bolted them all together. The silver is a little more 'blingy' than I want, but they have really faded after heating them glowing red.
Old 02-15-2005, 03:23 PM
Default More.. (since I can only post one pic per post (grrr)
Here's what it looks like IN the car..... You can see how the wastegate is coated in black and silver, like the carb. Strange how it all comes together like that. The turbos will also be coated with the turbine housing in black and compressor side in silver, not only for coordination but because the black is a higher temp coating. (and check out those cogs!)
You can see in this top pic where the turbo is aimed so the tubing will route under the core support...
Old 02-15-2005, 03:26 PM
Here's another angle of the car when I finally got it out of my 1-car garage (where I did most of the work) and ready to go to LG....
Old 02-15-2005, 03:35 PM
XcYZ's Avatar
XcYZ XcYZ is offline
Cool write up. If you'd like, we can compile this and maybe get more in depth and include more pictures on a dedicated webpage here on Lateral-g. This is the kind of info that's hard to find but is a great resource.
If you're interested, shoot me an e-mail.
My LS7 69 Camaro
Old 02-16-2005, 03:26 PM
Pro T Mustang's Avatar
Pro T Mustang Pro T Mustang is offline
Great job,I like the bosch dizzy to LOL!!!!
68 Mustang Coupe,5.0 EFI ,T-5 5speed,18" ADR's,275/40/ rears,225/40 fronts....yeah a start.
Old 02-16-2005, 05:17 PM
This thing took a while to get going, so I had the drill in there and on the primer to keep all the works gooey during the build up. Unfortunately, someone swiped my drill and primer while it sat at that shop. Probably that dude standing next to the truck in that pic.
