Old 07-30-2013, 12:19 PM
lutzy lutzy is offline
Default 275 Font tire size 69 camaro?
Anvil said I would be able to fit a 295 tire on a stock sub-frame but with their widened carbon inner fenders..sound right?
I was looking to just put a 275-35-18 on my car with the anvil carbon fenders. I have a stock sub-frame, tubular a-arms, 2" g-force drop spindles, wilwood disk brakes.. will be buying a new set of forgelines wc3's with a 10" wide up front. Any advice?
Old 07-30-2013, 12:32 PM
Track Junky's Avatar
Go with a backspace of 5.5".
Gaetano Cosentino
Old 07-30-2013, 12:46 PM
Matt@BOS's Avatar
Matt@BOS Matt@BOS is offline
That doesn't sound right to me. My understanding is that the front tire width on a 69 Camaro is limited not by inner fender clearance, but by the stock subframe itself.
Old 07-30-2013, 01:16 PM
thats what im not sure of..
Old 07-30-2013, 03:39 PM
Ron in SoCal's Avatar
To the best of my knowledge, if you get a 295 on a stock sub and you'd be (at least) one of the first in history. Hollywood Cassanova has a website showing how to get a 275 on there. IIRC that was on a 17" rim.
I'd bet Anvil's advice was limited to clearance of their inner fenders?
Ron in SoCal
69 Camaro in progress
Old 07-30-2013, 05:35 PM
Vince@Meanstreets's Avatar
ahhh I would not, remember you have them magic fenders Gaetano.
You gonna need 5.625-5.750 in BS to run it right then your gonna need inner fender well, sway bar and frame mods.
MEANSTREETS PERFORMANCE
Dealer for
NEVER FORGET -11
I'll have a 295 on mine next season........stay tuned
Gaetano Cosentino
Old 07-30-2013, 05:38 PM
I read widened fender and didnt catch inner......think your right Vince
Gaetano Cosentino
Old 02-07-2014, 06:28 AM
69Lt4's Avatar
69Lt4 69Lt4 is offline
Curious on the outcome of some of these projects. I'm would like to get 275's on the front. I currently have 245's up front and 315 in the rear. I have a stock subframe with DSE upper control arms and coil over. A friend recommended looking at the Anvil wide fender and inners. Planning on calling Anvil.
Any success stories to share?
Thanks,
Kevin
69 camaro LS2 T56...................
Old 02-07-2014, 07:05 AM
MarkM66's Avatar
MarkM66 MarkM66 is offline
Thanks,
Kevin
As said above, the tire will hit frame before the inner fenders, with a stock frame.
When you're turned at lock, how far is the tire from the frame?
