Old 08-16-2013, 06:32 PM
scherp69's Avatar
scherp69 scherp69 is offline
Default Issue with my welder, need input
As the title says, I'm having issues with my welder and trying to figure out how to fix it without sending it to the repair shop. It's a Miller 180 mig that is 3 or 4 years old. Today, when I flipped the switch to turn it on, it sounded like normal. The fan came on and it powered up. When I pulled the trigger though, nothing. Not a click or anything. If I bent the hose on an angle right below the gun, it would work again. Sometimes it would work for a while, other times I had to keep the hose bent to keep the wire feeding. Any thoughts?
Mike
Pro Touring 68 Acadian(Nova)
Prodigy Bar rear suspension
Wilwood 12.2" brakes
New Gen Splitters
LS3 and TKO600
Old 08-16-2013, 06:47 PM
Sieg's Avatar
Sieg Sieg is offline
Wires from the trigger are most likely the issue. Tear into it if you can and inspect them. Miller's website should have a pdf with an exploded view of the gun.
Old 08-16-2013, 07:53 PM
Rick D's Avatar
Rick D Rick D is offline
Yup millers site will have the diagram of what you will need! Like Sieg said it sounds like from all the twists and turns when welding have messed up the wiring??
Rick
Old 08-16-2013, 08:00 PM
Ketzer's Avatar
Ketzer Ketzer is offline
Mine is a little older than yours and I have had to replace the trigger already.
Jeff-
Old 08-19-2013, 05:36 PM
scherp69's Avatar
Thanks for the advice guys. Took the gun apart today and put it back together. Everything looked fine. Tried it again and now it works fine. Strange but I'm happy it's working again.
Mike
New Gen Splitters
LS3 and TKO600
