Old 08-17-2013, 07:51 PM
Lenie's Avatar
Lenie Lenie is offline
Default Help help, installed kill switch
My battery is in the trunk, had american auto wire install, their 10 guage wire went from my one wire alternator to the starter. I decided to install a big switch flaming river kill switch in the trunk, so what I did was disconnect and remove the 10 gage wire from the alternator to the starter and installed a 4 guage wire from the alternator straight back to the kill switch in the trunk to the battery side on the other side of the kill switch I connected the 0 gage wire from the starter. Here's my problem, before I began the switch the car started and ran perfect and now that I'm finished the car has a hard time starting, acts like it's flooded, runs really rough for a couple of seconds and dies. Any ideas? Here's a diagram I used for running the alternator wire to the kill switch in the trunk. Thanks
Lenie
Old 08-17-2013, 08:44 PM
Musclerodz's Avatar
If you only messed with the positive cable and not any negative cables the issue is either your new kill switch or the alternator is not working. It sounds your not getting enough voltage to keep the ecu happy. check the output voltage of the alternator, and if its good, there has to be an internal issue with the kill switch.
Mike Redpath
Musclerodz & Customz
facebook page
Old 08-17-2013, 08:45 PM
Che70velle's Avatar
Lenie, did you interrupt any grounding means during this swap? Does the starter turn slowly?
Thanks Dad!!
Old 08-17-2013, 09:09 PM
Che70velle's Avatar
Upon thinking about this a little, are you sure that you put the cutoff switch on the correct wire? I've always installed my cutoff switches on the ground circuit, instead of the positive battery wire. It removes all load from the switch.
I'm not saying it won't work the way you have it wired, I've just never done it that way.
Thanks Dad!!
Old 08-17-2013, 09:16 PM
Totally agree with using only the ground for killing stuff -- never the positive side!
Old 08-17-2013, 10:07 PM
Musclerodz's Avatar
Dumb me didn't pay close enough attention to your diagram on how you hooked it up. As others have stated, I would move the kill switch to the negative side, but if there is still an internal issue with the switch, it will still cause issues. I did go to Flaming Rivers site and they show the switches to be load rated, but always safer to switch grounds.
Mike Redpath
facebook page
Old 08-17-2013, 11:29 PM
Lenie's Avatar
Thanks everyone, I did disconnect the negative and positive while installing, in the morning I'll switch it over to ground and see what happens. Appreciate the quick responses, I am an electrical dummy!
Lenie
Old 08-18-2013, 12:00 AM
DRJDVM's '69's Avatar
Take the switch out and connect the 2 wires.... If the issue is gone, it's the switch itself, not the location in the circuit
Old 08-18-2013, 12:10 AM
Lenie's Avatar
Bingo, thanks Ned.
Lenie
Old 08-18-2013, 12:58 AM
ErikLS2's Avatar
ErikLS2 ErikLS2 is offline
I'm late to the party as usual here but it doesn't remove the "load" from the switch to have it on the ground side, it just removes the voltage from it as the "load" in the circuit (bulb, starter, computer, etc.) uses up the voltage before it gets there. Amperage though is the same throughout the circuit, power or ground side. Most vehicle manufacturers place switches on the ground side as the lower voltage reduces the very minor arcing across the contact points (where there isn't a transistor these days) caused by the additional voltage going through it and in theory making the switch last longer.
If removing the kill switch didn't solve the problem check for voltage loss across all the wires in the circuit. This is important, do it with the circuit operating. Set your meter to volts and connect it to each end of any wire you want to check. In your case each end of each black and red wire as well as across the kill switch contacts and alternator wire. On the large gauge wires going to the starter you'll have to disable the ignition system and measure it while cranking. I would pay special attention to the wire from the alternator (it might be too small for that span) and on this one the engine will have to be running, if it will run, if not while cranking will have to do. You should read very little voltage in any of these test, not more than 0.1-0.2 volts is ideal, if more than say a volt there's way too much resistance in the circuit or the wire is too small in diameter.
Erik
69 Camaro
