Old 08-26-2013, 08:06 AM
LDB LDB is offline
Default 67 Wheel fitment help
I'm finally ready to pull the trigger on some new wheels/tires for my 67 Camaro. Stock 10 bolt rear with drum, stock disc breaks up front. I did have the rear leafs de-arched 2 1/2". I'm going with the Ridler 695(cheap). I've searched the forum and there are so many different opinions on wheels size. Can some explain the benefit of an 18" over a 17"? Our roads are brutal here so I'm a little concerned with 18". I found these wheels on sale and I'm ready to order but I want to make sure. I want the wheels to tuck nicely and tires need to fill the wheel wells.
F- 17x8. 4.75" BS. 225/40
R- 17x8. 5.5" BS. 255/40
OR
F-18x8. 4.5" BS
R- 18x9.5 5.5" BS
Can some please tell me this is correct?
I would consider 18" if there's a benefit.
thank you
Old 08-26-2013, 08:58 PM
LDB LDB is offline
Nothing??? Was there something wrong with my post? I'd like to get this figured out so I can buy these while their on sale.
Old 08-26-2013, 09:20 PM
Rod P's Avatar
Rod P Rod P is offline
really dude, chill, you only posted 50 min before and then you want an instant answer
Rod Prouty
My websiteAuto-cross 101
Bangshift Stories
Old 08-26-2013, 09:25 PM
Rod P's Avatar
OR
F-18x8. 4.5" BS
R- 18x9.5 5.5" BS
thank you
18 allows you to have bigger brakes, and theres a larger selection race tire available, bad side is that the 18" tires cost more
17 limits the big brake kits, tires are cheaper
I changed the front tire size on the 17's
F- 17x8. 4.75" BS. 245/40
Rod Prouty
Bangshift Stories
Old 08-27-2013, 07:46 AM
LDB LDB is offline
Thanks Rod. I thought I was prett chill, I didn't know if I needed more info in the original post that's all. It seemed like I was getting views but no response.
Old 11-04-2013, 06:19 AM
Nisu Nisu is offline
I have same kind problem. 67 Camaro drum brakes all around. I want put Hotchkis TVS 2" drop front and 1,5" drop rear and Baer track 4 13" disc front and SS4 12" disc rear.
I´m thinking 18x8 4,75bs rear wheel. How much space I should live to rear outside fender and inside ? On rear side wheel opening it´s very narrow only 11 3/4" and I can´t fit 5,25bs wheel. 255/45 with 18x8 4,25 bs leaves about 1/2"-3/4" gap, so is that enough ? How much hotchkis tvs system allow rear side movements ?
I can´t make measurement with this parts because those are just coming.
And front I´m thinking 17x7 or 8 4,25-4,50 bs, what is suitable and also tire size? I want to keep good balance of car and also outside look as well.
Old 11-05-2013, 12:49 PM
67Rally's Avatar
67Rally 67Rally is offline
Here's what I learned when researching tire/wheel combos for a first gen a few years back...
In order to center the wheel in the openings these are the best backspacing numbers (wheel diameter doesn't matter 15,16,17,18,19,20,etc):
Info for an 18" setup:
18x7 4.25" BS
18x8 4.75" BS
18x9 5.25" BS
18x9.5 5.5" BS
18x10 5.75 BS
225/40's will (almost) always fit up front with the right backspacing. 235/40's have a good chance of fitting without issues. 245/40's are pushing it and might scrub on the inside on tight turns.
255/40's will (almost) always fit in the rear with the right backspacing. 265/40's have a good chance of fitting. 275/40's are pushing it and might scrub on the inside if the suspension isn't tight.
