Old 09-02-2013, 08:32 PM
JeffPeoples JeffPeoples is offline
Default ATX spindles vs stock A-body -weight difference
Hello All,
I am completing a final update of my 72 GS by adding tall ATX spindles I have had in the box for a while. Other than the geometry change improvements, they are made from aluminum, and are lighter. I thought everyone might want to know just how much lighter. The smaller numbers on the scale are pounds, the larger ones are kilograms.
[/IMG]
[/IMG]
Just over a pound of difference. Both have the respective steering arms included. Note that the ATX spindle has long studs, and the stock spindle has a Kore3 aluminum hub/short studs, so maybe there will be a bit more weight savings without those factors.
I have taken some other measurements, if anyone would like any other details of the differences.
Jeff Peoples
Mississippi
Old 09-28-2013, 09:02 AM
tigerchevelle tigerchevelle is offline
Jeff,im running the stock spindles tall ubj,lbj, and the kore3 brackets.would you be willing to sell the hubs?i still have the cast iron turn down hubs.phil
Old 09-28-2013, 09:40 PM
Some else here PM'd me about buying them already. If he changes his mind, I will let you know.
Jeff Peoples
Mississippi
