Old 10-12-2013, 03:09 AM
NorCal72's Avatar
NorCal72 NorCal72 is offline
Default Nodular S case or Nodular heavy duty case
Hi,
Im having Rons Rear end build my third member right now. Going with a True Trac 31 spline. My question is Nodular S case or Nodular heavy duty? And Steel or Aluminum pinion support? I need to let them know ASAP, any input is appreciated.
Looking at 6-700hp and a lot of cruising, minimal Auto X, road racing. I know I should have went S trac and 35 spline but I already have the axles and I don't plan on doing any 5k 1/4 mile launches on stickys. Im running this until I kill it.
Kevin
72 PT Camaro currently getting Quardralink suspension installed at Meanstreets Performance
29' Ford Roadster Ratrod
57' Big Window Chevy
Old 12-30-2013, 05:43 AM
blown32's Avatar
blown32 blown32 is offline
Kevin,
I am also talking with Ron and Wendy about putting a 9" together for me, (I have heard nothing but good positive information about Ron) I was going with the Nodular S case and 31 spline with the DSE Quadralink. What brand and size brakes did you use? Did you get your rear end back and installed?
Old 12-30-2013, 09:15 AM
Ron Sutton's Avatar
Originally Posted by NorCal72 View Post
Hi,
Kevin
If you are referring to the Strange nodular case as the nodular S case, it will do the job quite well. It is a great balance of light & strong. We raced them for years with no failures or problems.
31 spline axles will be fine, if you have a good brand. Your weakest link will be the Tru-Trac.
The aluminum "Daytona" pinion support is a good choice with larger pinion bearings which are needed IMHO. The only challenge here is many of the aftermarket aluminum Daytona pinion supports don't offer enough press fit for the front seal & they occasionally push out. Peening 3-4 spots around the outside of the seal helps. If you still have seal issues, let me know & I'll hook you up with a bolt-on seal retainer bracket.
Best wishes.
Ron Sutton Race Technology
Old 12-30-2013, 10:51 AM
blown32's Avatar
Ron,
Yes Strange nodular case s what I am referring too.
Thank you for your great input!
John
Old 12-30-2013, 11:23 AM
Ron Sutton's Avatar
Originally Posted by blown32 View Post
Ron,
John
No worries. Glad to help.
Old 12-30-2013, 06:06 PM
71RS/SS396's Avatar
Best wishes.
Ron, are you referring to the Strange/Ford SVT steel case?
Old 12-30-2013, 06:32 PM
Ron Sutton's Avatar
Hi Tim,
We don't get them from Ford/SVT so I don't know if we're talking about the same unit. It could be, because Strange makes the stuff for Ford.
The Strange nodular iron "S" case is inexpensive, lightweight & plenty strong for moderate Road Course & AutoX track duty with the 3.062 case bearings & Daytona pinion support (larger pinion bearings).
The regular nodular iron case is stronger & heavier.
When I need stronger than the "S" case, I go with the Strange "HD Pro aluminum" case (still with 3.062" bearings if the application is 31 spline. It's stronger but not such an anchor on weight as the regular Nodular iron case.
Old 12-30-2013, 06:43 PM
71RS/SS396's Avatar
I think the case I'm using is the investment cast steel case that Strange makes for Ford racing, C&R Racing built it, suppose to be the same case the cup guys use, it's 10lbs lighter than the N case.
Old 12-30-2013, 08:34 PM
What gears are you running? Considering selling the third member from my DSE axle complete with no miles. Just rolled on never power through.
Believe it to be 4.10 (will verify) but wanting lower myself and probably going aluminum. Just putting it out there.
Texas A&M BSME 2008
1969 Camaro - Hugger Orange
1969 C10 SWB - Hugger Orange
1992 Corvette ZR-1
2021 Ford F250 Tremor
