Old 10-16-2013, 03:44 PM
gstill gstill is offline
Default Malitude questions
I would like to know the oil pump /pan configuration used on MALITUDE.
I'm going some what the same direction as this motor setup and considering a dry sump system. Looked like this car kept the intrnal oil pump. Thanks for any info.
Old 10-16-2013, 04:24 PM
camcojb camcojb is offline
It had an LS oil pump with an ATS wet sump oil pan and remote filter. It was not a dry sump.
Old 10-16-2013, 08:48 PM
OLDFLM's Avatar
OLDFLM OLDFLM is offline
Default Fasteners
Jody, do you remember where you got the hardware and washers you used on the car? I remember they looked great and were affordable...
Ty Ingle, USAF Retired
FREEDOMBIRD
Old 10-16-2013, 09:10 PM
carbuff's Avatar
carbuff carbuff is offline
Jody,
Apology for the perhaps stupid question, but how does that work? Does the LS pump pull oil from the pickup out of the pan through the filter and back into the engine from the input side of the pan fittings?
Old 10-16-2013, 09:58 PM
Ring Brothers for the fancy ones in the engine compartment.
Old 10-16-2013, 10:03 PM
Originally Posted by carbuff View Post
Jody,
Yes, it still uses an oil pump pickup tube in the pan. It elimnates the oil filter mount that the stock pan has so you get two #12 fittings (in/out) to run a remote oil filter. Autokraft has a pan that comes with a machined oil filter boss that bolts to the rear side of the LS block to keep a stock type filter in place and eliminate the need for a remote filter and lines.
Old 10-17-2013, 06:37 AM
Thanks for the info. Does anyone know of more ls engine forward mount twin turbo cars . Building a 68 Camaro tube chassis car and trying to check all my options.
